Right well I have had my monitor for a few days now...
Didn't reply straight away as I wanted to live with it for a bit to see how it settled!
First up I came from a 17" iiyama TFT & was slightly concerned if it was going to be a big enough difference moving to a 20" WS. My fears were unfounded as I am very pleased with the increase in overall size. Widescreen gaming is immense, HL2 & CSS look fantastic, I really am blown away by how good it looks
Also as I only sit about a foot or so from the monitor, I don't think it needs to be any bigger!
Luckily I have zero dead or stuck pixels..Phew..& no discernable backlight bleed either..Double Phew
Mine also came in the 05 box, no signs of being opened before hand. But as with the others the monitor itself is the 00 version as previously mentioned. And as per Philips specs here
http://www.consumer.philips.com/con...proxybuster=01KYBFY1HSUEXJ0RMRESHQVHKFSEKI5P#
& previous posters this is the spec I believe!
Aside from that, the monitor was very easily setup as you would expect, dvi connection to my 1900XT, restart Windows, installed the drivers, selected 1680 * 1050 & that was it...Oh & it is incredibly bright
So had to reduce that a touch. Have not felt the need to mess around with colour profiles as it seems pretty much spot on straight away to me.
