Right, well I ordered this monitor yesterday and it arrived today. So here's my mini review of it so far (bare in mind I've only had it running about 2 hours since I've got in from work)
Packaging
The box said it was 16ms and the 05 model on the outer packaging. However, the monitor was well packaged. First thing I noticed was the weight. It feels solid and the plastics used at first felt like a metal, nice and sturdy. As mentioned it is quite weighty, but 90% of that is the mental in the base to keep the monitor secure. On the back however the sticker states it is the 00 model. So maybe they are just using older stock of boxes but putting the newer 00 model inside?
Setup
Setup couldn't really have been simpler. The DVI cable is already connected to the monitor, so I just plugged it into my graphics card. The monitors VGA connector right next to the DVI, which my X360 is now connected to. Then switched PC on, booted fine. Changed the res to 1680 x 1050 @ 60Hz. First impressions was rather shocked at how clear text was! So much clearer than my 17" Mitsubishi 740SB CRT monitor. Colours were great out of the box too. However I popped the CD that came with it in and installed the drivers. It just limited the refresh rates and resolution. I also installed the program FPAdjust that was on the CD, which guides you through a monitor calibration wizard, which was pretty painless, but it didn't change the settings much. I then went mooching on deviantart for some juicy wallpapers! So far I haven't noticed any dead/lazy pixels either which is a bonus!
Connections wise there is as mentioned DVI, VGA, a usb input to enable the usb on the front left side of the unit. Audio wise there is an audio input to use the monitors speakers (haven't tried them yet) and a headphone socket.
OSD
I then went fiddling with the OSD menu. The only settings (as with most monitors) you can mess with when your in DVI mode is contrast and brightness. I changed the brightness to 36% and contrast to 50% for now, which seemed to take the "glare" off the whites. From the OSD you can change the input on the monitor from DVI/VGA, adjust brightness/contrast. You can adjust the colour temperature from 6500k, 9300k, sRGB, Original colour and user define. You can also as mentioned earlier by Raymond lin that you can set the way the monitor scales. This allows you to run in a lower resolution without having it streched across the screen and making it look blurry. You can also set the audio for the screen up and adjust the image placement (i.e. up, down, left, right)
Gaming
PC - Right the most important section
The only game I have played on this so far is HL2. First thing i said to myself was wow at the clarity of textures etc, nice clear, vivid colours, looked far less washed out than on my CRT. I then went round running like a headless chicken trying the response times. Going from a CRT with virtually no ghosting, I did notice slight blurring of textures when moving extremely rapidly over walls with my cursor, but I don't normally do this in game. There is slight ghosting, mainly in the dark/black areas of the games, although not enough to stop you seeing what you're doing!. In the lighter areas it wasn't really too bad. It wasn't enough to put me off the game, put it that way!
Xbox360 - Only thing I have tried on here so far was FNR3 demo, and woopey, no black borders! This was using the VGA cable, set at 1360x768 - widescreen. I'm yet to try PGR3 to see what that looks like. I'm glad I went widescreen now though! No real ghosting noticable in this game, but its not that fast paced.
Misc stuff + pictures
Right odds and sods time!
Viewing Angles - Although nowhere near as good as CRT, the viewing angles are pretty good. You can still see a nice clear image from both sides, although it at extremes the screen has a white wash over it. Horizontal and Vertical angles were also pretty good, again at extreme angles (Which i'd never view my monitor at anyway) there was a white glare over the screen but more apparant on these angles.
Here is some pics
Reference picture, head on viewing angle
Top down view
Top right view
I couldnt get a good lower viewing angle shot due to there not being enough room below the monitor to fit the camera, but its about the same as the top down view.
End of part 1 lol.....
