Pirates Ahoy!
Oh dear. It's descended to this sad state of affairs has it?
Ok then :D
Why does it take pirates so long to learn the alphabet?
Because they can spend years at C!
\o/
Only problem I have with Rosetta is the *)*£"!)%&) huge amount of memory each WU takes up! If you have a quad core it eats around a Gb of Ram :eek:
Can vouch for that Biffa. At the mo, Rosetta is using ~850MB spread over four cores. I have seen it as high as ~1GB though for the four, which is ludicrous when compared to other projects. Still, everything runs smoothly enough on my rig, which has 2GB RAM - so it's not as bad as it seems.
Ahoy Me Matey
LoL, I wonder if they'll get that across the pond :D
Captain Kidd and his crew were on the high seas when they were attacked by Blackbeard, their arch enemy.
The first shot by Blackbeard's gunners took off Kidd's forward mast. The second shot splintered the center mast, and the third desintegrated the rear mast.
Panic stricken, one of Kidd's men asked what they should do.
"We have no choice but to surrender", replied the pirate, "He's using weapons of mast destruction!"
Read the whole thread Biffa :P
Ok then :D
\o/
I'll have my Q9450 come about and start hunting some pirate's this evening, once I've cured cancer :D
"All hands to the deck"
I have a couple of spare cores on my quad, they are not spare anymore as they have been thrown in to help and if i get no BSOD then consider them 'ours' for the foreseeable future. :)
Well I've been trying to find out as to why my RAC is so low on my AMD chips and I think I've almost cracked it so expect an extra 3-400 points from me :)
Damn those pesky pirates, my seti fleet was doing so well..
Will peel off another attack squadron tonight and send it your way, 4 cores setting sail as soon as I get home...
are there any optimised apps for rosetta?
*hoist by me own petard.. arrghgh*
No optimised app, no GPU app, and the points you get from Rosetta are less than for other projects.
But hey. Thats not the point is it, its the.. er... sci.. er.. .. erm... HOIST THE MAINSAIL, ALL HANDS TO THE GIBBETS! *baaaaaaahggh*
“The pirate captain's list was to starboard when he failed to ketch his bottle of port which fell onto the poop deck after he nearly keeled over.”
Cool. If the info is likely to be of use to anyone else then might be worth posting it. :)
Today I have done 3,645 so far and you have done 3,218... so neer!
Just keeping you on your toes, and don't think you're home and dry either. :p
