Post your FTTC line stats & unlocking info
Anyone got any ideas as to what happened here?
Resynced from 72/20 to 74/20. Upstream attenuation increased on all bands whereas downstream didn't change. Downstream Tx power rose whilst upstream fell.
Bak in March:
Code:
# xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 32287 Kbps, Downstream rate = 101040 Kbps
Path:   0, Upstream rate = 10000 Kbps, Downstream rate = 39999 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3939)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      32287 kbps        101040 kbps
Actual Aggregate Tx Power:        6.6 dBm          13.2 dBm
  VDSL Band Status        U0      U1      U2      U3      D1      D2      D3
  Line Attenuation(dB):  3.9     19.6    28.3     N/A    10.3    24.5    38.2
Signal Attenuation(dB):  6.5     18.2    27.5     N/A    10.3    24.5    38.2
        SNR Margin(dB):  20.8    21.1    21.3     N/A    24.8    24.4    24.8
         TX Power(dBm): -5.7    -30.1    6.4      N/A    10.2    7.9     6.2
Code:
# xdslcmd info --show
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 32323 Kbps, Downstream rate = 101040 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        24.7            21.3
Attn(dB):        0.0             0.0
Pwr(dBm):        13.2            6.6
                        VDSL2 framing
                        Path 0
B:              240             239
M:              1               1
T:              64              35
R:              14              0
S:              0.1917          0.7622
L:              10644           2519
D:              19              1
I:              255             120
N:              255             240
                        Counters
                        Path 0
OHF:            1025896         236595
OHFErr:         0               1
RS:             65673485                3670537
RSCorr:         23              0
RSUnCorr:       0               0
                        Path 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    242991356               0
Data Cells:     3368567         0
Drop Cells:     0
Bit Errors:     0               0
ES:             0               1
SES:            0               0
UAS:            17              17
AS:             3157
                        Path 0
INP:            0.00            0.00
PER:            3.06            13.33
delay:          1.00            0.00
OR:             83.48           37.18
Bitswap:        3               11
No idea what any of this means, if it's good or bad?
This is the photo of the engineers testing kit that I took:
Now:
Code:
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 27352 Kbps, Downstream rate = 76776 Kbps
Path:   0, Upstream rate = 20000 Kbps, Downstream rate = 79999 Kbps
DS: (32,859) (1216,1963) (2792,3959)
Attainable Net Data Rate:      27352 kbps         76776 kbps
Actual Aggregate Tx Power:        6.6 dBm          13.3 dBm
  Line Attenuation(dB):  4.0     20.1    29.9     N/A    10.5    25.1    39.2
Signal Attenuation(dB):  6.6     18.9    28.2     N/A    10.5    25.1    39.2
        SNR Margin(dB):  13.6    13.6    13.6     N/A    5.0     5.0     5.0
         TX Power(dBm): -5.4    -23.9    6.3      N/A    10.3    7.8     7.0
Code:
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 27356 Kbps, Downstream rate = 76776 Kbps
Mode:                   VDSL2 Annex B
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        5.0             13.6
Attn(dB):        0.0             0.0
Pwr(dBm):        13.4            6.6
                        VDSL2 framing
                        Path 0
B:              239             237
M:              1               1
T:              23              45
R:              0               16
S:              0.0955          0.3782
L:              20107           5373
D:              1               1
I:              240             127
N:              240             254
                        Counters
                        Path 0
OHF:            1553290844              3943888
OHFErr:         178731          6253
RS:             0               4291984
RSCorr:         0               32461
RSUnCorr:       0               0
                        Path 0
HEC:            632122          0
OCD:            0               0
LCD:            0               0
Total Cells:    1067155029              0
Data Cells:     3180991188              0
Drop Cells:     0
Bit Errors:     0               0
ES:             56245           4817
SES:            147             27
UAS:            17              17
AS:             9670997
                        Path 0
INP:            0.00            0.00
PER:            1.64            4.25
delay:          0.00            0.00
OR:             116.56          60.17
Bitswap:        1704507         13995
any idea what profile 30a is?
Code:
xdslcmd profile --show
Modulations:
        G.Dmt   Disabled
        G.lite  Disabled
        T1.413  Disabled
        ADSL2   Disabled
        AnnexL  Disabled
        ADSL2+  Disabled
        AnnexM  Disabled
        VDSL2   Enabled
VDSL2 profiles:
        8a      Enabled
        8b      Enabled
        8c      Enabled
        8d      Enabled
        12a     Enabled
        12b     Enabled
        17a     Enabled
        30a     Enabled
        US0     Enabled
Phone line pair:
        Inner pair
Capability:
        bitswap         On
        sra             Off
        trellis         On
        sesdrop         Off
        CoMinMgn        Off
        24k             On
        phyReXmt(Us/Ds) Off/On
        TpsTc           AvPvAa
        monitorTone:    On
        dynamicD:       On
        dynamicF:       On
        SOS:            On
        Training Margin(Q4 in dB):      -1(DEFAULT)
also can someone tell me if its worth upgrading to sky pro which is 80/20.
does it look like from my stats i would get the full speed.
Code:
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 36545 Kbps, Downstream rate = 118012 Kbps
Path:   0, Upstream rate = 9995 Kbps, Downstream rate = 39998 Kbps
Mode:                   VDSL2 Annex B
TPS-TC:                 PTM Mode
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        27.3            25.5
Attn(dB):        0.0             0.0
Pwr(dBm):        13.4            1.8
                        VDSL2 framing
                        Path 0
B:              239             235
M:              1               1
T:              64              7
R:              0               16
S:              0.1909          0.7508
L:              10055           2717
D:              1               1
I:              240             255
N:              240             255
                        Counters
                        Path 0
OHF:            1071033         278007
OHFErr:         1               0
RS:             0               331178
RSCorr:         0               0
RSUnCorr:       0               0
                        Path 0
HEC:            0               0
OCD:            0               0
LCD:            0               0
Total Cells:    251989257               0
Data Cells:     2236145         0
Drop Cells:     0
Bit Errors:     0               0
ES:             1               0
SES:            0               0
UAS:            30              30
AS:             3287
                        Path 0
INP:            0.00            0.00
PER:            3.05            11.82
delay:          0.00            0.00
OR:             65.46           152.21
Bitswap:        0               0
Does anyone know how to re-enable the web interface on the Huawei HG612 on LAN-2? I'm not sure why I can't connect to the Huawei HG612 when connected to WiFi... HH3.
Possibly due to routing as I can't even ping the Huawei HG612 address but it's live.
I vaguely remember that my unlocked one randomly changed its IP address.
EDIT are you connected to it via LAN 2? Are the link lights up?
Huawei HG612 > BT HH3 > Client
Huawei HG612 = 192.168.1.253
BT HH3 = 192.168.1.254
Client = 192.168.1.65
Yes, link lights up.... LAN 2 > BT HH 3
@MilanoChris, can you connect to your Huawei HG612 through the HH3 fine? Do you use another router (not HH3?)?
after 400k a second, my new fibre installed today gives me:
the engineer said my upload speed should hit nearer 10 mb's but very happy. that test result is through my homeplug downstairs.
