Post your FTTC line stats & unlocking info
BusyBox v1.9.1 (2010-10-15 17:59:06 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
# xdslcmd info --show
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 2
Max: Upstream rate = 7730 Kbps, Downstream rate = 46084 Kbps
Path: 0, Upstream rate = 7197 Kbps, Downstream rate = 37189 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.3 7.1
Attn(dB): 0.0 0.0
Pwr(dBm): 11.0 -2.4
VDSL2 framing
Path 0
B: 63 223
M: 1 1
T: 64 39
R: 16 0
S: 0.0548 0.9884
L: 11687 1813
D: 589 1
I: 80 112
N: 80 224
Counters
Path 0
OHF: 1749330923 1740938
OHFErr: 33076 15928
RS: 864087848 4293810
RSCorr: 149423277 0
RSUnCorr: 1062236 0
Path 0
HEC: 294739 0
OCD: 0 0
LCD: 0 0
Total Cells: 3440145586 0
Data Cells: 1870107988 0
Drop Cells: 0
Bit Errors: 0 0
ES: 10499 28907
SES: 62 84
UAS: 259 259
AS: 4616217
Path 0
INP: 3.00 0.00
PER: 2.62 9.63
delay: 8.00 0.00
OR: 63.91 26.56
Bitswap: 1696910 398378
Has now been connected for around 112 days. Tempted to re-sync to see if will get higher but too scared!
Just hacked my modem to get my real line stats and noticed something a little odd:
Status: Showtime
Retrain Reason: 0
Max: Upstream rate = 7392 Kbps, Downstream rate = 39628 Kbps
Path: 0, Upstream rate = 7392 Kbps, Downstream rate = 32399 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (868,1207) (1972,2783)
DS: (32,859) (1216,1963) (2792,3959)
Medley Phase (Final) Band Plan
VDSL Port Details Upstream Downstream
Attainable Net Data Rate: 7392 kbps 39628 kbps
Actual Aggregate Tx Power: 1.2 dBm 12.2 dBm
VDSL Band Status U0 U1 U2 U3 D1 D2 D3
Line Attenuation(dB): 7.4 43.3 N/A N/A 18.9 52.2 0.1
Signal Attenuation(dB): 7.4 42.8 N/A N/A 18.9 52.2 N/A
SNR Margin(dB): 6.1 6.1 N/A N/A 6.6 6.6 N/A
TX Power(dBm): -9.9 0.8 N/A N/A 10.3 7.8 N/A
Does this seem a little low to anyone else? The installation engineer checked the line and quoted around 115/35 as my attainable, and having an upload of only 7.5 attainable seems a little odd. Anybody?
can you post the other part please xdslcmd info --show
Looking at line attenuation and signal attenuation and the fact you are only using 2 up-stream and down-stream tones means you a quite a distance from the cab.
What was the estimate from BT checker?
The wholesale checker listed my line as 7.5mbps.
This is a direct copy/paste from my modem stats:-
Profile State UP Speed Down Speed SNR Upstream SNR Downstream
17a Showtime 796 (Kbps) 5186 (Kbps) 123 (0.1dB) 50 (0.1dB)
FTTC was installed wednesday, my sync hasn't settled down yet.
How can I calculate how far the cabinet is from my house?
Using GoogleMaps the cabinet is roughly 1 mile (via roads) from my house.
~ T
@ThomP
Using the roads is a pretty good guide. You're about 1600 metres from the cabinet, so your speed isn't that much of a surprise, to be honest. What speeds were you getting on ADSL?
That ECI stuff is a bit over my heard really. Think I'm going to try and get hold of a HG612 from Ebay.
Could I connect this up to my machine and do all the config I need to before actually plugging it into the VDSL line - so its just a simple plug in and away we go?
Code:
# xdslcmd info --pbParams
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 21778 Kbps, Downstream rate = 71280 Kbps
Path:	0, Upstream rate = 20000 Kbps, Downstream rate = 71642 Kbps
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
Attainable Net Data Rate:      21778 kbps         71280 kbps
Actual Aggregate Tx Power:        6.5 dBm          12.4 dBm
  Line Attenuation(dB):	 0.7	 28.7	 44.0	  N/A	 14.3	 37.1	 58.1
Signal Attenuation(dB):	 0.7	 28.5	 43.9	  N/A	 14.3	 37.1	 58.1
        SNR Margin(dB):	 6.0	 6.0	 6.5	  N/A	 6.5	 6.1	 5.9
         TX Power(dBm):	-5.2	-16.3	 6.2	  N/A	 9.5	 7.8	 4.4
Code:
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 21733 Kbps, Downstream rate = 71280 Kbps
Mode:			VDSL2 Annex B
TPS-TC:			PTM Mode
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 6.2		 6.3
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 12.5		 6.5
			VDSL2 framing
			Path 0
B:		239		236
M:		1		1
T:		21		5
R:		0		16
S:		0.1066		0.3771
L:		18009		5410
D:		1		1
I:		240		255
N:		240		255
			Counters
			Path 0
OHF:		11866741		526990
OHFErr:		6952		26
RS:		0		1740008
RSCorr:		0		263
RSUnCorr:	0		0
			Path 0
HEC:		14178		0
OCD:		0		0
LCD:		0		0
Total Cells:	2754776663		0
Data Cells:	44950767		0
Drop Cells:	0
Bit Errors:	0		0
ES:		617		24
SES:		8		0
UAS:		71		71
AS:		20005
			Path 0
INP:		0.00		0.00
PER:		1.67		6.12
delay:		0.00		0.00
OR:		114.34		203.67
Bitswap:	6538		147
Just a bit of a bump, as the thread seems to have gone quiet. When the engineer came to install everything I'd already unlocked an Echolife modem using the help in this thread, so he gave me a spare :cool:
Can anyone tell me anything about my stats, that's not already obvious? I.e. I'm at the sync limit at what the line can achieve.
Here is a route map from our house to the FTTC cabinet, http://goo.gl/maps/YMu5d although I would trim 100-150m off for the roundabout so I would say we're closer to 650m from the cab.
