No I know that - a fantastic success story. It was more my surprise you could even pay thousands for a metre of silver plated copper. I didn't realise high end cables went quite that high.
You can pay a lot of money for even the most simple items - there's a market for everything
I'm usually of the opinion that if it's your money, you can do what you want with it, but 4K a metre is expensive. What you've got to ask yourself, is do you think B&W use the same silver plated copper cable on the inside of their speakers? The answer is almost definitely not; and there in lies the problem. What's the benefit of running such expensive cable if the cable inside the housing itself isn't the same "quality"?
It's the same reason they don't bi-amp; their little metal connector is deemed "good enough: for all their speakers, and this is coming from the manufacturer.
The
MOST important thing when it comes to sound, however, is buy what sounds better to YOU.
If, indeed, Crinkle preferred the sound of the pricey cable, and he has the money, they it's inherently better value, regardless of price. It's just important to make sure it was the cable making the difference
