- 5 Aug 2006
- Kent, UK
If anyone sees a discount on milwaukee quik lok head, hedge trimmer, pole saw and grass strimmer, please let me know.
If only they made them in whiteWe need to recruit @LiE
Not sure I'd count Dyson as 'British'. Sure lots of R&D is done here but he offshored the holding company in the months after the Brexit vote after endorsing vote leave and all the manufacturing is done offshore.
I went down a right Instagram rabbit hole yesterday but did catch a small clip of a bloke battling Milwaukee/Dewalt gear. Basically cable tying them to each other and sticking the trigger. I may have dreamed it tho tbf.Polesaws at dawn! Fight!
How do you find that pole saw with the extended shaft?Polesaws at dawn! Fight!
I was thinking about buying one.
) at which to tackle branches at - you don't want to be under a branch when it comes down as they are deceptively damn heavy and can fall in unpredictable directions. It might sound pretty obvious but I wouldn't have the polesaw totally upright when cutting and make sure you have the space to make a sharp exit when any awkward branches fall.
. A few weeks ago when the weather was better I set about some overhanging branches that were getting too low and heavy and starting to compete for light with the monkey puzzle tree.I bought an Einhell sander for a single job, using my landlord's money, and still was grossly disappointed. I guess there's a gap between cheap and not worth using.Ryobi is the king of cheap tools.
My exp with Einhell leads me to tell people to stay clear. Cheap plastics, loud, lack power and poorly built.
I do mainly heavy brush cutting so that means metal blade, U hand and harness and 2x18v from Makita.Looking to get a battery powered strimmer but not quite sure where to start & what brand etc. Looking to get a decent battery system but as I only do DIY level stuff (Shelves etc) I don't think i'll need anything too high in price. Any recommendations? I've been looking at Einhell at present
It's pretty good I reckon, a few comments I'd make:
- it's a bit "bendy" with the extension but this is to be expected when there's the weight of the batteries and motor at one end and the chainsaw and oiler at the other. It's not a problem, just something to be aware of when lifting it up. I am considering adding another extension pole to improve the angle of cutting and reaching higher but that'll make it even more bendy and may stress the drive shaft of the unit, but the manual doesn't say it can't be done.
- the automatic chain oiler needed a little fettling to get the right feed amount, it wasn't feeding at all to begin with.
- it tackled all the branches I put it up against, I was surprised how quickly it went through them (new chain helped here).
- it has a little hook on the end to help bringing any stuck branches down.
- compared to the 2-stroke I was using previously it's a delight to use - no fumes, constant noise or the awkward positioning because of the hot engine.
One thing I was acutely aware of was the angle () at which to tackle branches at - you don't want to be under a branch when it comes down as they are deceptively damn heavy and can fall in unpredictable directions. It might sound pretty obvious but I wouldn't have the polesaw totally upright when cutting and make sure you have the space to make a sharp exit when any awkward branches fall.
Here's a little game of Spot The Difference. A few weeks ago when the weather was better I set about some overhanging branches that were getting too low and heavy and starting to compete for light with the monkey puzzle tree.
Less than an hour later I'd made a big improvement but also made a lot more work on the ground delimbing and cutting the branches plus some shredding.
It's difficult to see because of the million shades of green but that was a lot of branches taken down!
If you need a polesaw and are in the Makita ecosystem already say to definitely get one, just wish I had earlier.
My nephew bought a small erbauer set about 5 years ago inc the saw, abused then royally and they're all working still.Anyone had experience using the (basic) battery powered Erbauer Circular Saw?
Thanks I ordered one! Know where to get spare chains for it?
.My nephew bought a small erbauer set about 5 years ago inc the saw, avoided then royally and they're all working still.
I've got drill, impact, sander, multi tool, SDS& hand held vac.
The vac is pish, the rest are decent.
Spares are almost impossible to get though
This, invest in the Freud Diablo circular saw blades designed for battery circular saws, they transformed my Milwaukee circular saw, it's now my most used tool, I hardly ever use my battery Mitre saw, it's awful, wish I hadn't got the battery one now, 18V just isn't powerful enoughI am going to try the Freud blade designed for battery mitres too before I sell it...
definitely worth investing in decent blades.
