- 14 Jul 2005
- Birmingham
Has anyone tried using those angle grinder mortar raking bits, rather than a cutting disc?
Any good?
Any good?
This is a great video! Thanks for sharing.my issue with all of those type of solutions (apart from the price) is that they waste 50%ish of the depth of the shelving. Good for a grab and go, but not great for longer storage. So I made my own drawer units from left over plywood - basically a bodged version of these
Decent videomy issue with all of those type of solutions (apart from the price) is that they waste 50%ish of the depth of the shelving. Good for a grab and go, but not great for longer storage. So I made my own drawer units from left over plywood - basically a bodged version of these
Correct in that they won't use the full depth, the shelves are 60cm back to front and at a guess i'd say the dewalt boxes are 20cm or so. The drawers are very smooth which i like and the compartments are ok. I'll likely put things like my angle grinder behind them in it's box as that only get used every couple of years if that.If you want the drawers to be really smooth, then 240 ish grit sanding followed by wax. I used some old car hard paste wax - works well there and on my table sawThis is a great video! Thanks for sharing.
#remindme 5 yearsIf you want the drawers to be really smooth, then 240 ish grit sanding followed by max. I used some old car hard paste wax - works well there and on my table saw![]()
A lot of sites don't allow mains stuff is what I understood. Sds is still a powered tool to me.After 15 years my old screwfix SDS finally gave up. That beast went through some big old jobs.
Was surprised to see so many battery powered SDS drills now. Are folks really getting on with this over full powered wired units?
Really depends on what you want to do and how much £££After 15 years my old screwfix SDS finally gave up. That beast went through some big old jobs.
When I was tempted by the Milwaukee SDS, it did have significantly less joules than the Makita powered one. This was 4 or 5 year ago, tho.Battery tools are very powerful these days, the gap is basically zero for standard tools.
Short of dealing with dense reinforced concrete, I’m not sure you’d have any problems with a decent battery SDS over a mains one. You’ll be fine for anything you’d need to do to a house.
They are also safer and easier to use due to the lack of cable.
.I split my SDS into a lightweight 2j for standard hole drilling and a cheapo monster for smashing stuff. Pretty sure your 240v is probably c2.5J, not sure what is equivalent in Makita 18v worldI'd really like to test a battery SDS drill to see if it can compete with it's 240V equivalent.
I was putting up a few shelves and some racking in the garage recently which meant a lot of drilling. My 18V combi hammer action with a masonry bit could do it but it just took too long for the first few holes, this supposedly quick job was going to take ages. So I got the 240V SDS big boy out and it drilled the walls like they were cheese, effortlessly quicker.
I'd love a battery SDS drill as it would be more convenient and portable, but as yet I'm unconvinced so I'll be keeping the 240V SDS, for at the moment at least.
. It seems that single battery versions max out at 2.0J like what Buffman posted and to get higher require the twin battery versions. The impact energy isn't even mentioned for my combi, probably less than 1.0J equivalent.My 'normal' hole drilling 18v SDS is 2J. My cheapo corded is c8J and nearly weighs thatJust looked it up and you are so close, it's 2.4J. It seems that single battery versions max out at 2.0J like what Buffman posted and to get higher require the twin battery versions. The impact energy isn't even mentioned for my combi, probably less than 1.0J equivalent.
They're nothing compared to that Dewalt 13J monster that born2sk8 mentions!
