the previous week i 1000(d/a) it all and 1200 wet flat especially round the stars so the clear lays flat/er on it next clear coat.
Sunday finished off prep, blew in a few areas and painted the h/light surrounds, engine lid hinges and engine lid
Monday quick sweep of floor, wiped ceiling sheeting, sprayed with water the wall sheetings to try to keep dirt down to a minimum for the last clear coats!
three clear coats applied / HS so theres plenty of the shiny stuff to mop the hell out of
this morning/Tuesday removed wall and ceiling sheets and demasked doors and bonnet - left window masking on till polished
painting finished !!!!!
only thing is now all the sheeting is down i've remembered what a hole the garage is !!
pictures much the same but the painting is finished.
Really great job, looking on getting the wifes Paris convertable sprayed very soon, as the welding work is coming along and that will be the next stage.
I'm hoping to have a go at spraying mine eventually. I've got only one question!. How did you go about spraying the area behind the grille above the engine bay ? (the one between the engine bay and the back window). Did you have to spray in-between all of the slats?.
today being the official day of work on the bug I :
1500 DA all over followed by 3000 DA, took an hour or so then spent the rest of the day waving the mop about :crazy:
yes all my own work, thought it is what i do for a living so it owt to be good really
thanks for the comments, i cant wait till its on the road, i want to put the wings on but i've got joints up front + disc conversion, and a gear box to change so i should wait really.
waiting for replies on turbo stuff, ignition and box atm.......
