- 18 Mar 2008
when you say blue fan, do you mean blue led fan? if so, I imagine it would be barely visible behind the vented plate
There are loads, Lian Li keep the same dimensions and fittings for a lot of the areas on thier cases so all the accesories fit on many different cases. It's probably the most comprehensive amount of accesories made by any manufacturer.
