that just needs the mesh and a dvd bezel to finish it perfectly
Will be meshing the rad cutout soon, maybe this week. Going to use some circular perforated steel. Was going to use a honeycomb mesh but think it'll look out of place. Just not sure wether to use the exact same perforation size as is on the case or go with something a bit bigger and less restrictive.
Hi Jeff, I think I've got the same fan controller as you. Mine is directly beneath the bay reservoir, and the bluray will be going directly underneath that![]()
Cracking thread. Great read, and very educational.
The final product looks great. I think that if I had gone to the trouble of building a setup like that, I would need to use it as an excuse to clock the crap out of the CPU and GPUbut I appreciate that you're after silence and stability.
Anyway - great build.
