- 1 May 2013
- M28
£30.39 on cdkeys with 5% Facebook code
£56.99 DLX ed.
£18.99 Season pass
£56.99 DLX ed.
£18.99 Season pass
Yeah my wife complains about the shifter noise too lol, you seriously need a man cave. Not much work done in my office now, if I WFH I have to sit at the dining table lol
My biggest gripe is the lack of feedback when braking in all games does the load cell help?
The load cell brake is excellent it works on pressure rather than position, apparently muscles are better at remembering pressure so when you press the brake it's easier the know where the locking up point is.Is the Alacantra rim good, thinking of getting either that or the GTE to replace my 458 Italia one as it is a tad too small.
I switched from G25 pedals with a Nixim brake mod to the CSR Elite pedals with the load cell and even then the difference was night and day when it came to braking. Being able to adjust the amount of pressure required to reach 100% braking is great.My biggest gripe is the lack of feedback when braking in all games does the load cell help?
You could always put a custom wheel on it.Is the Alacantra rim good, thinking of getting either that or the GTE to replace my 458 Italia one as it is a tad too small.
Yeah subbed his channel, stunning work, its a shame I use VR because I would just be looking at the wheel all the time.Check out Leopoldo Ramirez on youtube. The man's an artist, and his art certainly doesn't come cheap!
Had my first go on this tonight, and I'm impressed. My first race was in the diablo on spa historic and I was grinning ear to ear.
I hit the limits of my motion sickness on california highway (too many hairpins!), but had a go on a thunderstorm and it was ace. Puddles are just treacherous! As they should be of course.
Really looking forwards to pushing my VR legs a bit more now that I know I can, and looking forwards also to dialing my settings in better. Currently I'm just using the default raw ffb settings. Also need to tweak my graphics settings a bit I think.
RAW is the strongest of the flavours, if you map a couple of keys or buttons to FFB volume you can tweak it on the fly while driving in session. It really is very good isn't it? To get the hang of the driving I'd say start off in the slower stuff even though the Ferraris and Lambos are very tempting FRookie and Ginetta Jr are good fun. If you want a monster track Bathurst is just the dogs...but quite tricky.
I just set my wheel at 900 degrees rotation in game and drive each car as it comes, they all feel a bit different then. I don't change the rotation...why do you do that? Some cars are supposed to have slower steering. You can change that in car setups if you want as well.
I have it on defaults. No I don't see 1:1 movement, that's the issue I'm having.Do you have steering sensitivity set to 50 and are you seeing 1:1 movement with your wheel and the in-game wheel?
I'll have a look through and fiddle with some settings. Thanks! Off to Munich tonight but will have a go when I'm back this weekend (also get to try out my caster cups to see if they are better than the old shoe method)
