Project: Fallen Angel
Absolutely beautiful m8, another lovely creation. The vortex fans look amazing on the cooler, definitely better looking than the spectres. As i said before, the detail painting on the ram really sets it off, im doing a painting job in a hotel at the minute, it involves a lot of tiny brush detail work, if your ever stuck for a job w3bbo let me know m8.:). Ill be looking forward to your usual overclocking results, particularly on the sli 470's. Thanks for sharing this build project m8.:)
nice build but personally i dont like it.
i must admit your last build was the best ive seen,the case and styling was amazing and to be honest i am a fan of all thing's white when it comes to a pc build.
how long before we see this on the members market w3bbo ?
This build should put me on unti x68, I have no plans to change anything until then. Might make a few tweaks here and there but I'm content for hte time being....never say never though lol ;).
I see you went with a fan behind the gpu's, mind if i ask w3bbo, what sort of temps are you getting on the 470's?
I can run some benchies for ya now m8 - what do you want to see them running (my screen is 2560x1600 btw so gpus under huge stress :D).
I havn't replaced the TIM yet - waiting on some ic diamond first;).
kk, I'll install it now.
What settings? I take it you will want me to run at your spec for comparison?
Gimme your cpu speed and res + heaven settings. Highly doubt my temps will be any good tbh but it'll make a good basis for comparison as we have pretty much similar setups.
Cpu at 4ghz, (20x200), 1600mhz ram, 1920x1200, 4xaa, normal tesselation in heaven. My gpu's are currently at 751/1502/1674, stock voltage of 0.987. Cheers m8.
Yep, ran it just now myself, max temps of 81-77c on the gpu's, 52-46-49-44 on the cpu. Also it's best to run it twice as the minimum fps on the first run is very low due to texture loading.
Result for comparison.
Hmmm. For some reason the voltage on mine is a bit lower than yours resulting in 69/65c temps. Trying to find out why I can't get the voltage up to yours for a proper match up.
