It didn't work. But I'm not going to blame you melmac.![]()
Had some spare time, so re-installed Windows this afternoon.
Still doesn't work.![]()
Oh, forgot to write it here - works perfectly on my B-I-L's computer.
It will be something in windows, mine did similar until i wiped it. ALthough it could be a piece of software or something not connected with windows that getting in the way.
Now i dont know what the reinstall has done but a full and complete wipe did fix mine but it needs to go back on properly.
He did a complete reinstall, it didn't work. Your reinstall worked because you were using an N version of windows and a dev version at that.
Somethings to try, if you aren't too busy.
Can you connect the headset to the display port the Monitor is in? connect the monitor to a different port.
Try disabling XMP and setting the memory to 2400Mhz.
Already tried both those.
I do very much appreciate both the suggestions and the emotional support on this thread though.![]()
Support sent a suggestioin which seemed very sensible - a clean boot.
So booted the system with only Microsoft and Oculus services running... still didn't work!
How is this possible!?
Incompatible with my GFX card somehow?
From memory, I think he has a 1660. Possibly a Ti.
