Caporegime
Isnt the IF supposed to be set at half your ram speed? Cheers
Yup, set IF at 1600 and RAM at 3200.
3: The IF clock is also independently controllable on 3rd Gen Ryzen. Want to try that sweet 1800MHz Infinity Fabric, but don't have DDR4-3600? That's fine. You can put it there manually--it's adjustable in 33MHz jumps.
I'll be keeping an eye on this thread but I don't think any amount of voltage will get me beyond 1800MHz FCLK.
But I'm happy enough as it is. Pushing for more whether that's more raw speed or faster timings I doubt will win me much in terms of FPS in gaming titles.
An FCLK of 1800MHz and a ram frequency of 3600MHz CL16 is plenty.
It's probably not stable with a score that high and would explain why some stuff stops working. Have you tried running prime or aida 64 to test the fabric stability because memtest doesn't always pick it up?.Ohh... this is the thread I need:
I found out yesterday that if I push my SOC voltage to 1.2v I can run an FCLK of 1900. I didn't like the dram calc timings I tried though. Mostly CL16 and my score in the default bench of 250 was worse than my 3600CL14 of 221.
I'm not sure 1900 is doable even if it seems stable because I was finding the mouse and keyboard where sometimes becoming unresponsive.
Dropping to 1867 was better but still didn't like the scores I was getting from the default bench mark.
I can find loads of articles on line, including from Corsair and Gigabyte saying 1.2v on the Soc is the upper limit of safe but is that really true? I'm quite sure I read once that there is a thing with the X570 boards where if you go over a certain threshold with Soc voltage you get PCI-E 4 issues and for sure 1.2v on the Soc is well over that threshold.
So do you say, stick with my fast and easy 3600CL14 or spend the time to find out where I'm at at 3800MHz and 3733MHz using up to 1.2v on the SOC?
Also do I need to play with the VDDG and VDDP voltages, I couldn't discern if they where actually making a difference or not when I was increasing them compared to just stock.
Another thing to consider is running that much voltage through the soc may create extra heat and lower boost clocks slightly.
probably just need a bit more Dram voltage.My system is weird, it ran fine for the last 2 days t 1900/3800 then this morning refused to boot at that. I tried 1800/3600CL14 today instead which was going well but COD:MW crashed twice.
Now I'm running at 1833/3666 and it's stable so far.
1.4 is just the voltage they set for XMP its not the max 1.5v would be the max if its the same as the 16gb kits maybe @8 Pack can confirm?.I've already been up to 1.4v which is the max range on the product page.
My 3200/14 kit says 1.20-1.40v yet 8pack himself has said these are fine up to 1.5v daily hence why i'm running them 3800/14@ 1.49v.The product page for my 32Gb kit says Tested Voltages: 1.20 - 1.40 V where the ripped edition ones say 1.40 - 1.50 V
For 24-7 1.5v is fine on Samsung IC. Heat spreaders are also only for looks no cooling is needed.
If it's like other B-die then it will be 1.5v providing it's getting some airflow else you will probably get errors and have to knock it down to 1.45@Gibbo can you confirm the max safe voltage for the 32Gb 8Pack kit please? I don't want to push it beyond safe limits.
https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html
