You can do 3600Mhz c16 at 1.35v since its B Die, unless he got a very bad binned IC which should not be the case because his kit is rated 4000Mhz
But why wouldn’t you just run it at spec given 1.4v is totally safe for the memory...
I might as well be new to AMD, so still reading up on what is what, but I upped my 3900x IF to 1800 and am using Taichi motherboard with 2400Mhz Corsair Dominator 4*8GB (17, 17, 17, 40,57 2T) which I reused from my previous (intel) system. And I did a modest amount of CCX tweaking without tweaking voltages, the system is running is running hot, but windows stable and CB15/20 stable.
Temps when relying on the bundled consumer air cooler get a bit toasty. I'm hoping this week's switch to an AIO with a large radiator will help offset that a bit.
Default FCLK was 1200. Pushing it up to 1800 has been fine so I mention only because I'm using "slow" RAM. All the posts so far are with with higher spec RAM. I don't know if my post will be useful for someone to consider in a similar situation or for those who know more than I about these things.
You want to keep your IF 1:2 to memory frequency. So if your IF is 1800MHz your ram ideally should be 3600MHz.
You can run either faster/slower but you get a latency penalty for doing so.
How would this latency manifest itself? My CB20 scores went up when I shifted from 1200 to 1800, so I'm not noticing anything there.
Quick question as I want to find my fastest IF speed, how the hell do I stress test it? Also when I bump up my RAM speeds surely it puts extra stress on the IF making a once stable IF unstable once it has faster RAM tugging on it? Bumping IF speeds up and booting to windows doesn't seem enough to be 100% certain being 100% stable. TBF I have Hynix C and I don't think it's going to be that good, rated @3600mhz I think I'll be lucky for 3200mhz with decent timings.Your ram speed is determined by your max stable IF speed.
Find that first, and then set ram to x2 IF.
Use dram calc to help you.
Likely very similar to G.Skill F4-4000C18D-16GTZSW. If so, try 3600MHz with DRAM @ 1.4v and SOC @ 1.1v and timings 16,17,17,36,54 1T with GDM On
I'll try and remember to chuck my full timings your way.
Just because it can do 4000MHz, doesn't mean it's going to do lower speeds well with tight timings.
Have you got a full set of timings to post here at all @Rossi~?
I have 4x8GB sticks of the 8 Pack 3600MHz rated RAM and can't get this anywhere near stable using the DRAM Calculator. I'm on an ASRock X570M Pro4 with the latest ABBA BIOS. Even though the CPU boost clock has been 'fixed' on this BIOS it's crippled my stability on my RAM overclock completely![]()
Just built a Ryzen system. 3600x, 3000mhz ballistix ram. Should I set the Infinity Fabric at 1500mhz? Or should I try something higher first? Does the IF have to match half your RAM speed? New to this AMD stuff
I can get my ram to 3200mhz, anything after that just blue screens windows. Just unsure about the IF. Some say to set it to 1900mhz and go from there.
Any ideas chaps?
Isnt the IF supposed to be set at half your ram speed? CheersStraight for 3200mhz should be a good start.
