Man of Honour
- 11 Dec 2002
- Darkest Norfolk
I've just done the move from Rocket Rom v10 4.0.4 to alliance, to do so i've run a full Titanium backup of all apps and system data.
- installed the alliance rom manager: https://play.google.com/store/apps/details?id=com.ficeto.alliancemanager
-Download the latest rom from sourceforge
-download the custom settings apk from here
-copy both the rom and customsettings to the internal SD card (external sd fails later down the line)
-Start up ROM manager and select Flash / install File, select the CustomSettings.apk and install to system.
-Once thats installed I restarted (to take my sim out..) but you may not need to, close Rom customizer and reopen, select the new ROM settings item and ROM Config Settings.
-Turn everything on (if you want) but make sure you have Wipe User Data enabled.
-go back to the main screen, select flash install, select the alliance rom zip and confirm.
-cross all available body parts and wait...
-breath again when it starts up
-start restoring from Titanium (need to read up on the best way to do this actually...
