Suspended
- 18 Oct 2002
Yup, def worth giving them a call if you don't get the option online.Check if you can change delivery date, we're expecting ours tomorrow. Unless you have your reasons for that date, then ignore me.
Can't see option online. But it's OK. Thursday is one of my days off work.
They have a live chat system, which I used to return order butAnybody got a phone number for Samsung to change delivery date? Tried 8007267864 it don't work.
Thanks mate.They have a live chat system, which I used to return order but
I used this number to eventually get throuh to the right support 0333 000 0333 when cancelling an order. Hopefully the same for changing delivery.
Yeah if it's already dispatched, but his order is due Thursday (not sure if sent out yet)You can change it when it gets picked up by DPD via the DPD app
Nice one! Mine is due in the next couple of hours. £40 extra but a week earlier, I can live with that (codes are no longer working too apparently, just got in in time).
Codes still work, managed to get it down to £1,095.19 just now.Nice one! Mine is due in the next couple of hours. £40 extra but a week earlier, I can live with that (codes are no longer working too apparently, just got in in time).
Was that stacking them? I could never get it to use two of themCodes still work, managed to get it down to £1,095.19 just now.
Yes stacking and you do run the risk of getting your order canceledWas that stacking them? I could never get it to use two of them
Text on this 2nd panel hasn't been an issue for me, I think it was some issue with image scaling that I managed to sort out in the settings, but as I didn't have the issue until I got G9 assumed it was the monitor.
Now I'd be happy to recommend this monitor for more mundane tasks as well, if you can avoid a fully white background.
I had this issueImage scaling is set to 100% on the G5 (as it's 5120x1440 it doesn't need zooming in to 125% & zooming out doesn't help either as tried 75 & 50%). The 28" were set to 125% & retained perfectly crisp text all the way up to 175%, but I do think the higher horizontal resolution helps a lot as well. Even went as far as trying al the different fonts & sizes in web browsers to no avail. Maybe my eyes got used to the 28" text display & the G5 is perfectly fine and I am expecting too much from it. Text in games seems fine though which is what baffles me as run games at the native resolution without DLSS or DLAA so if their is a real issue it is with Windows (BIOS is stretched across the full width of the screen unless set it to PBP mode but isn't "pin sharp" even then still)
That's a very long Friday!Well DPD took their time today but give the guy props he delivered it at 7.15pm!!! Window was 12.14-13.14
