Yep, I have been checking that but my power draw and temp are well below the limit required for the fan-stop to turn off which Zotac stated:It's not the monitors it's the idle power draw of the Graphics card.
Download CPUID or similar and you will see this.
How can I enable/disable fan-stop on certain graphics card models? | ZOTAC
<p>The FREEZE fan stop is a feature available only on certain models. Look for the label or FREEZE badge on the packaging of the graphics card or on the product page or product brochure.</p> <p>The FREEZE fan stop feature is automated and is enabled out of the box. There is no user interaction...
"We checked on the specifics for the fan stop
GPU temperature >= 55C OR GPU loading >= 120W, than fan ON
GPU temperature < 55C AND GPU loading < 120W, than fan OFF"
And I am well below those numbers on both.
Currently idling at 120hz = 39 deg and 24W, fan is off.. if I change to 240Hz those dont change drastically and are still below limit, but the fan will not return to stop after load until I change the Hz. Same issue happened with this card on 2 monitors now but not on my old 3440x1440.
Its not an issue specific to the G9, but I am looking for 4090 suggestions where this is not an issue with this monitor. cheers
