Thanks sven256.
Do you know if the 2 year warranty with Samsung still applies? Or is it 90 days only.
As far I know 2 years with Samsung, It's just 90 days return to OCUK. That's the way it normally is.
Thanks sven256.
Received today, Like it a lot, Would love it except for the flickering issue when using Displayport, I only have the cable supplied by Samsung to hand so will have to order one.
Pretty shocking sending out ****** cable's like this Samung!
If you mean tiny sections of the screen flickering, a new cable will do nothing. Well I have used two now and both do the same.
Hm that doesn't sount right, The whole screen turns off for about 1 second then comes back on, As if its actually been powered off briefly.
I'm on HDMI now and it's fine, Except for that fact its 30hz lol.
I have ordered the cable coded:CDLDP-002LOCK someone mentioned above which they said resolved the screen on/off issue.
That's a different thing then. The think I'm on about has been reported numerous times in this thread, it's tiny glitches on screen.
I've not tried 30Hz but I get the momentary glitches (usually bottom left) with both DP at native 60Hz and/or any combination of settings using DVI at below native and also when using PBP modes using any combination of inputs.
At this point I'm 99% convinced the 4K scaler/signal processing isn't really ready.
Rroff did you have the AOC 29" superwide currently on TWO for £259.99 or am I thinking of someone else. If it is you, is it any good, would be mostly gaming rpg style and watching movies on Blu-ray, surfing etc. Sorry to be off topic.![]()
Not me - I do have the Dell U2913WM which is a super wide 21:9 2560x1080 though. They are pretty decent panels in general with a lot hitting 75Hz without any tearing/frame skipping. I think the main problem with the recent 29" superwides was that there seemed to be a high chance of getting one with worse than average backlight bleed other than that they are decent panels.
After having had the monitor for 3-4 days It's driving me a little mad so I think it's going back, Running on DP with the cable supplied by Samsung creates massive flicker so I bought another cable that someone said stopped the flicker, It arrived today and it's flicker just as bad.
Like this
Any idea's?
