Sky Fibre Pro use the Bulgarians, apparently they're terrible.
actually, they're very good - i've had speed problems with sky fibre pro since my fibre was setup about a month ago.
Been in touch with tech support (the Bulgarians (lol
), not the regular sky call centre you get when you first call up about something) numerous times, had 3 engineers sent out, had several callbacks from Sky to monitor how my speed is etc.... - next one scheduled for Tuesday. Point is, as far as the Bulgarians are concerned i've found them nothing but helpful; when it comes to engineers the visit has been sorted out for the next day or so.
Long story short, when my fibre's working properly i should be getting almost a perfect 80/20. Coincidentally, had that from tuesday afternoon, when it looked as if openreach had finally sorted out the fibre problem at my cabinet (problem identified & confirmed), until this morning, but dl speed has once again dropped to about 64 (upload still at 20 for now). No idea if the problem has reoccured because i've noticed on the router stats that the downstream noise margin has increased from 8.5 to 12, so that could be the cause of the speed drop - a temporary drop, i hope, caused by openreach messing around/testing profiles.
Anyway, my main point is that Sky tech support (or the Bulgarians - i'm familiar with them because i think they used to handle tech support for Be) are fine/get things sorted out quicky, if you're unlucky enough to have a tech problem & need to use them - the problem in my case has been openreach not sorting out the problem quickly enough after it's been identified
on a more positive note, 100 posts for me &, i guess, free delivery
