Just lookin at changing my main skyq router or adding another for wireless coverage really, any good units upto £100 mark, thanks
Are the SkyQ Hub Boosters still available?
Yes they are. £40 from sky.
Great, are they available to order online or just by phone?
Hi JezThat'll go faster eventually, when the DLM drops to 3db. I think all cabinets now try to train down to 3 (from your 6.2). Perhaps see as much as +10mbit once it adjusts![]()
I'm assuming Sky tech would have a clue if I called and spoke about this sort of thing or have the ability to do anything about it.....Your noise margin still has loads to give, does anyone know if certain ISPs request different targets from openreach?
My line is with TalkTalk and it trains down to 3db, if yours did the same then you'd see a fairly significant uplift, i am surprised that it hasnt which makes me wonder if openreach allow individual targets per provider?
They wouldn't book an engineer just reset your profile.I'm assuming Sky tech would have a clue if I called and spoke about this sort of thing or have the ability to do anything about it.....
And would that force the noise margins reduce do you think @MissChief ?They wouldn't book an engineer just reset your profile.
Potentially, but no guarantees. Give it another week or two.And would that force the noise margins reduce do you think @MissChief ?
Not a lot. Apple devices seem to have issues with multiple sky Q hotspots and will refuse to jump between them and prefer to remain connected to the first spot they pick up. 8ts under investigation.After two weeks without broadband my connection was activated on Friday. Speeds while wired seem good but wifi is slower when 2.4G and 5G networks are synced. I've read that if I disable this it breaks the SkyQ mesh with the TV box, but I have that plugged in via ethernet. What am I losing by running separate wifi networks?
Are your hub and Q box close to each other? If so I'd recommend disabled the hot-spot option on the Q box. Home, highlight settings, 0,0,1 select.
Downstream Upstream
Connection Speed 39999 kbps 7043 kbps
Line Attenuation 23.5 dB 0.0 dB
Noise Margin 6.8 dB 5.5 dB
I was going to see about getting the Max, but i don't think i could get anymore than this.
There's another option, Fibre Unlimited Plus for an extra £2.50? Will get you up to 55Mbps?
So original stats when first installed
Connection Speed 39050 kbps 5973 kbps
Line Attenuation 24.1 dB 0.0 dB
Noise Margin 6.1 dB 6.6 dB
and a few months later
Connection Speed 37977 kbps 5797 kbps
Line Attenuation 24.2 dB 0.0 dB
Noise Margin 6.3 dB 6.6 dB
recently lots of reboots due to Skys broken fibre backbone to ns/dns
now have,
Connection Speed 33929 kbps 5960 kbps
Line Attenuation 24.4 dB 0.0 dB
Noise Margin 5.7 dB 6.6 dB
how do I get the speed back as its stuck at this speed for two weeks, no sign of DLM boosting it back up
