Cable or wireless?
Surely cable. I'm not that stupid to test it on wifi.
![Wink ;) ;)](/styles/default/xenforo/vbSmilies/Normal/wink.gif)
Cable or wireless?
Also is there anyway to improve ping value?
Guys
Safe to say I can get fibre unlimited if the postcode search on Sky website shows the below on offer? Silly question but it hasn't been a clear question for them to answer
Just done a speed test on mine which is normal Sky, 1.17Mpbs download and 0.65Mpbs upload.
I can't even stream radio!
Will have to ring Sky and get Fibre added on as normal Sky is getting worse every day!
Have you guys seen a slight bump in speed for the 80mb package? I keep getting around 11.5-12MB/s
The origin download speed isn't calculated correctly.
so for 10 days i ahve had a bad connection, so i decided to get mysefl a 30m ethernet cable, though i needed only half, if that, and connect my PC directly to the router.
form getting 3-4mb download speeds, i now am getting about 36mb.
which is great, BUT, i was using devolo dlan AV200plus x3.
do i need to get 500mb homeplugs? if so what would be the best ones for sky fibre? the tp-link ones?
would i also be better of by getting a differnt router aswell?
how do you order Sky Pro Fibre?
You have to call up sky and ask to be upgraded. I did so earlier today, and have to wait 24 hours before the upgrade. Here's hoping it will happen overnight![]()
