- 16 Jun 2007
- London
Does tp link do a fibre router with a gigabit switch built in? If not where should I look? Don't have the greatest budget mind
Let us know your speedtest result with the pro package.
I want to see if you are able to get the full 80/20 speed.
I don't remember the exact number now but it was roughly in the range of 18-24ms. Is this normal?
I will try again after I got back home. (no beer tonight, so I promise)
UPDATE the ping to bbc is ~18ms
Really appreciate if someone can share his/her ping to bbc for comparison.
C:\ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=18ms TTL=247
Reply from 212.58.241.131: bytes=32 time=19ms TTL=247
C:\>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.244.71] with 32 bytes of data:
Reply from 212.58.244.71: bytes=32 time=6ms TTL=56
Ping statistics for 212.58.244.71:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 6ms, Maximum = 6ms, Average = 6ms
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\pshellie>ping www.bbc.co.uk
Pinging www.bbc.net.uk [212.58.244.69] with 32 bytes of data:
Reply from 212.58.244.69: bytes=32 time=234ms TTL=40
Reply from 212.58.244.69: bytes=32 time=232ms TTL=40
Reply from 212.58.244.69: bytes=32 time=226ms TTL=40
Reply from 212.58.244.69: bytes=32 time=252ms TTL=40
Ping statistics for 212.58.244.69:
Minimum = 226ms, Maximum = 252ms, Average = 236ms
Thanks Rossi~ I got basically the same numbers.
I really want to get 6ms though!!!!
Are you connected to the router via ethernet cable?
Are there any other devices in the house connected to the internet?
Do you have any other apps running which may affect speed? This could include torrent apps, ms outlook.
Pinging www.bbc.net.uk [212.58.246.92] with 32 bytes of data:
Reply from 212.58.246.92: bytes=32 time=7ms TTL=57
Ping statistics for 212.58.246.92:
Minimum = 7ms, Maximum = 7ms, Average = 7ms
Please be assured that I'm doing it properly. Of course it's via ethernet. No other apps.
They were just things that I overlooked when I first used to test. Not sure what the issue is with your ping.
Yea, scratching my head now.....
Considering I don't live close enough to get 80Mbps ( Max on the modem is 7bps) I'm hoping to get as close to 70mbps
Are you on Pro now? If so, how are the speeds?
