The engineer didn't give me the distance only said about the copper. I just did a guesstimate from google maps. I am fairly sure something is wrong as the first 10 day period to set up your speed should initially connect at the fastest possible and lower from there if its unstable. Mine has done the opposite and connected very low download wise whilst being completely stable (hasn't disconnected in 22 hours so far) which means that the test will simply say that the line is completely stable at that sync without testing higher speeds.
I am prepared to wait the initial 10 days just to avoid that initial fob off but am teetering on calling them. Only thing holding me back is the fact last week when I called I was on hold for 35 minutes!
Edit: Decided to phone! Have been on for an hour so far. Initial 13 minute hold, got through, gave advisor all info she then said she would transfer me to the fibre team! Another 15 minute hold. Through to another woman who tries to tell me fibre wasn't actually installed! She tells me she needs to re-place the order for fibre. After explaining it was and I can't go from 3.5MB/768k to 14.2MB/7MB on ADSL she puts me on hold to speak to her manager for 10 minutes. Confirms fibre was installed, goes through some line tests and calls me on my mobile. Then asks me to reset the sky hub, after doing so and telling her still 14.2 am told to wait a minute, then confirms still 14.2 so I need a new hub! Explain that the engineer got results when he was here and hub wasn't even connected. On hold as she speaks to her manager for 15 minutes and as typing this apologises and says they're trying to raise a fault with BT and there system is having some trouble, so on hold again!
I will sound like a complete sexist pig here but anytime I rang sky for my adsl (which strangely was limited to 2MB initially also) and I spoke to a female advisor they never knew more than the script they had to read. When I spoke to a male they always knew what steps to skip and were much shorter calls.
Still on hold...
