Solar panel production figures
Oh how do I join the pvout team???
Assuming you are already using pvoutput. Login, go to settings, and at the bottom of the page under 'registered systems' click on edit next to the system you want to sign up.
Under 'Advanced Settings' is 'Team Membership', search for the team (ocuk) and when it shows 'OCUK Radiation Sponges' click on it, and then click join.
No blue sky about today, quite cloudy, only 9.8 so far, also had my battery last night go from 67% to 4% just before flux charge period.
Somehow on a 13.5kw battery with 4% reserve the total charge of battery today was 12.4 despite only charging from grid between 02:30 and 04:30 then discharging til solar came online to 100%.
Has anybody with batteries considered switching to Octopus Cosy from Flux for the Winter months? It means that you get two opportunities to charge your batteries but the peak rate is much higher.
No, but you need a heat pump for cosy.
Capped out ~2600w on generation, not bad since there is a blanket of thin cloud covering sky (cant see no blue), imported 11, exported 9 and produced 16.6 so far but not even 5pm and im 300w away from breaking even on load/generation.
