As I have said previously I do my best to predict forward based on knowledge of my use, but I only have a single 8.2kWh battery installed as of now. Usage is much lower for me usually sub 10-12kWh a day, so even on a terrible solar day I can almost guarantee that the battery will cover all my needs unless I am charging the car, and that is done in the Go Faster window of 21:30 to 02:30.
Have you worked out your usage patterns yet, using your graphs, what time of day are you likely to use lots of power and when are you not? Even though I don't need to I still do heavy draw stuff like washing and tumble drying/immersion use when after 21:30 when I know it will be a terrible day the following day, and make sure the battery is fully charged to run the house for the 02:30 to 21:30 the next day. I know you can't do that due to your power use, but you can work it out, but it is all about data gathering, and you are unique so can't be compared to others.
Seasonal really, as if you check sunrise/sunset time, and predict generation you'll get a good idea of what state the batteries will be in once you've used the data gathered above. Sadly a couple of weeks of solar data isn't enough, but I know you are itching trying to get it all setup perfect. I suppose to some extent I don't have automation really, as I have a habit of checking at least once a day the weather, and then making sure I'll have the battery where I want it for the following day. Some people can't be bothered, but the system will pay back faster (it's being sold anyway) and I feel better knowing I did my best to lessen the load on the grid at peak times.
