I got 3.3kwh for today……covered my daytime use at least
Just wondering what your actual daily electricity costs incl. standard charge are? (for those with battery)
I don't have stats yet for a lot of time, only last month so far, and partially mine a bit cheaper because of Go. I hope to match similar this month.
Just over £1/day including SC and VAT. This is 01/09 - 26/09.
Most of my peak usage is just overage on consumption with high use equipment. Stuff like ovens will go above the 2.6kw my battery can provide (plus my regular home usage is 400w~) so I will always use some electric even if the battery is fully charged if I use certain things.
Since 27/09 - 20/10 I have drawn 170.84 kwh from the grid according to my inverter stats. This is 24 days so far so a little more consumption per day than the previous month, but most of it's off-peak again, and generation is lower in October.
The dongle doesn't like 5Ghz, if you're like me I've had to disable 5Ghz and set it up on a different access point instead.
Givenergy connects to a 2.4Ghz only access point, everything else connects to a different 5Ghz only access point.
Pain
Looks like each battery is 2250 inc VAT so that ties in about right....Have you asked for a price without the batteries but with the same inverter?
I say this as the batteries are only £1900+ VAT each to buy, and it might save you several thousands of pounds if you buy them and have them installed after.
I did not see a wired version of it.
Mine would outright refuse to connect when my BT WiFi had both bands enabled.
Just had a nice chat with another company, quote is £15k for 18x410w Trina panels (mono), 9x tigo optimisers for the bottom string, a 6kw solis inverter and 2x 5kwh Puredrive II batteries, scaffolding costs included. All parts in stock and ready to go.
That seems the best quote I've had so far and the guy on the phone was great. Do we think that's probably about as good as it's going to get in the current climate?
