You've doubled me!
So the shading from next doors roof has now transitioned to the top string, so solcast predictions of 14 and 17kwh the previous todays ended up as 5 and 4kwh..., so need to do some calcs and get some quotes for optimisers for the 8 panels that get shading, suspect it's going to work out cheaper to just accept that for 4.5 months of the year i'll be impacted if i'm losing out on say £3-4 per day at very worst case, but as i'd be charging my batteries to max at current rates it's more like 80p!
Yeah had priced it up! Do you need the TAP/CCA? Was considering doing it myself but thinking more about it, i'd probably be inclined to get the same fitters back in. Payback is main consideration, and obviously on the bleaker days the shading doesn't actually affect too much... Will ask for a loose quote and see what they say.Tigo TAP and CCA are around £240, and the optimisers are £42 each if buying 10+, if you did all the panels and fitted them yourself it'll be under £1000, who knows how long it would take to pay back but if payback is your only condition of purchase, then it might not be worth it.
No but yes, Tigo basically won't support you without a TAP and CCA anymore. Also there are fairly strong rumours of a firmware bug on the Tigos which is fixed by a firmware update which is only possible with the Tap and CCA (google for details). For me the monitoring is the best bit.Yeah had priced it up! Do you need the TAP/CCA? Was considering doing it myself but thinking more about it, i'd probably be inclined to get the same fitters back in. Payback is main consideration, and obviously on the bleaker days the shading doesn't actually affect too much... Will ask for a loose quote and see what they say.
Abysmal day today, total generation 0.2 kwh :3
Just rain!
Might be my worst day yet.
December is definitely going to be even more dire!
