How do we add ourselves to the teamTry above link again now you're logged in? Think it'll need to refresh overnight to a) get first batches of data and b) index for the team to show up (at the moment we don't as there's no data!)
I got the team too, added 5 days output…..still cant joinI found the team (go to teams and sort for the lowest generated) but it just displays no data found?? Not sure how to sign up
Solar is a permitted development, and unless you are actually inside a conservation area there is naff all they can do to stop you installing it. Link
You do not need any qualifications or certification to install panels.
OCUK Radiation Sponges Team Ladder
(thanks for name Solid!)
Oh was that you??? I do humbly apologise! I thought both your names were great and couldn't decide, hence mix up. Please forgive me!** Scratches head **
Would have thought radiation sponges myself.
What I was surprised about was they stipulated it needed to be an mcs installer for it to be exempt from building regulations i.e with a self install would need to get a building inspector around to sign off at cost
yeh, hopefully everyone on @Ron-ski list will join, be good to see all the info in there and ron-ski will have less work to do on his own excel sheetI’ve joined the team on PVoutput named as Oldmill after inputting manually. Still can’t see anyone else apart from @katie279 but hopefully over the next few days it will sort itself out.
Thanks to Solid for creating the team! I hope it updates and everyone joins it.
Am looking into repurposing a Pi to get Home Assistant setup and see what the Solis inverter offers.
its 5 uploads according to the settings in the help sectionIt seems that it'll take a while to update and you may need to have a minimum uploads before you appear on the league table.
Once I get my new system installed, then get Home Assistant setup I will eventually join as well, but that is some time off.
