- 20 Jul 2007
- A sunnier or damper area than Ron-ski....
Yeah, might as well be !Have you checked the rest of your neighbourhood are not plugged into your meter?![]()
This makes decent sense - maths is fairly easy to work out for payback, no reason you couldn't go batteries alone.Has anyone installed only batteries? I can’t explain it well, but I am not completely sold on solar. For ~5 months of the year the generation is rubbish, and it doesn’t seem to add any value to the house.
Batteries on the other hand are easily removable, and charging from the grid is relatively cheap at the moment. I know that the installation is VAT free if combined with solar, and I haven’t worked out what the pay off period would be with batteries only.
0.7 here been grim.
There's a cable run down to my houseHave you checked the rest of your neighbourhood are not plugged into your meter?![]()
Hi all, are these things really worth it?
My parents had some guy round trying to sell them a system and I don’t want them getting ripped off. I tried Google expected costs/returns but all I get is companies trying to sell me systems so I thought I’d ask here…
They’re looking at getting 13, 445w panels and a 6kW battery with all the associated equipment for £16,100 (£14.5k for parts and £1.6k labour), which seems rather excessive, especially seeing their home is a bungalow and therefore, I would assume a simple install.
Somehow, my parents use ~7000 kWh of electricity a year and the guy reckons the system will pay for itself in 5-6 years. I find this hard to believe as their roof isn’t ideal, facing a SSW direction (~240°). Also they are retired and use most of their electric during the day so I struggle to see how they would get much benefit having a battery installed.
Sorry for the splurge, but I’m rather concerned how keen my parents are to spend £16k based on one quote and I still can’t fathom how these things are expected to produce nearly 5000 kWh/yr.
I do think that is expensive though, but 445w panels are high watt panels, so basically pretty posh and probably a fair chunk more expensive than most installers would fit.
It'll be 2.1m x 1.1m panels as it is a bungalow so the roof is usually more forgiving to using the larger panels which in terms of W/£ are usually cheaper. You can get 460w CS panels for £166+ VAT.
That's what i meant240 is WSW not SSW btw
So its basically a west facing roof slightly tilted to the south
That's what i meant![]()
What a difference a bit of sun make...its 9:15am and we are already exporting to the grid, but we do have a very low base usage, even though i work from home.
same here......we had just enough to make .500kwh, but its clearing again nowSun stuck its head out here for 20 mins as well.
Cloudy again though
Praying for a couple of hours of clearish around lunchtime!
