Man of Honour
- 5 Jun 2003
- Falling...
Finally can put the washing machine and dishwasher on today... phew!
Finally can put the washing machine and dishwasher on today... phew!![]()
My mrs couldn't wait for the sun any longer and just putting the washing machine on.....i got the shakesWashing machine is on, but trying to avoid dishwasher at the mo, hence running war in the house as its GOT TO GO ON NOW111!!!!1 lolz
To which I informed her (lit blue touch paper) if she packed it properly there would be enough room to fit everything in, but ended up tight as she had put things on top of others (no idea why she cant get that they wont wash), but I got them all in, where they would all wash as well
TBH I will probably relent, what I really want to do is get the usage in the 5:30pm range where it would be relevant for an Octopus savings session (cant tell her that she will object)
Unless solar is high battery will drain today anyway so I am trying to go on grid in the window that is relevant for savings sessions on those days, little bit of tweaking going on in the app trying to get what I want to happen
What a difference a bit of sun make...its 9:15am and we are already exporting to the grid, but we do have a very low base usage, even though i work from home.
it may do.....but right now, someone stuck a big cloud on the roof lolThink Wales is in for replacing Kent as top sun spot for the end of 2022...
Also FF kitchen earlier:
New system finally up and running as of yesterday (16 panels @ 390w each, connected to a 6kW hybrid inverter with a 3.6kWh battery). Generated 2kWh so far (near Reading), which is pretty good for this time of year reading the thread?
AFAIU its size is related to the KW generated from the panels? Could be wrong though, i'm new to all this.A 6kW inverter sounds large. Does that mean you could pull 6kW out of the battery?
Blue sky here, with the odd cloudThink Wales is in for replacing Kent as top sun spot for the end of 2022...
Any hints on finding the team on PV Output?
You would generally size inverter to be at or a bit under panel capacity more than anything.
Ah okay, thanks. I've seen people mention a 3.6kW or 5kW inverter, but never a 6kW. There's much to learn
Octopus Energy are phoning me tomorrow about their solar offering. I haven't had a chance to research if other people have found them to be competitive.
