Does anyone have any recommendations for firms doing solar roof installs in the east Midlands? Our house is due a new roof and I figure it's wise getting one of them in built in type installs when we re-roof.
Can't recommend an installer, but you want to be looking at a GSE in-roof tray system as they have new trays that came out in 2022 compatible with nearly every panel size on the market, meaning you aren't stuck with very specific vendors. The trays are only about £40 each, and as such considerably cheaper than most tiles per square meter. They also have a new range of flashing and fittings, which make a totally black/grey roof look a lot better than what was previously on offer.
I'd look for a roofer that is able to also fit the trays/panels for you in conjunction with a PV installer who will do the electrics and setup for you, this should work out cheaper, and you'll still get the sign-off for export if co-ordinated correctly.
For installers all you can do is shop around, get some quotes locally to where you are and get a feel for the local market.
