Someone please help me decide :(
slightly retarded question but... will i need a wifi card with that amd build hono suggested as my office is the other end of the house to my modem
Why not a second hand GPU with the i5?
I just don't see the point in paying for the i3 when he said he will "add more after if it works". Might as well start with a quality CPU.
Never said he couldnt use a 2nd hand GPU with the i5K :/ Just pointing out the build is fast running out of control and his budget will have to increase.
Some people dont like buying second hand. I was just saying that I personally wouldn't buy anything less than the 2GB 7850 if he wants something brand new
not gunna lie... i didn't understand that thread, im running chrome though and it says there's an extension where would i find that?
No, I know. I was just wondering if there was a reason I was unaware of (which is stupid, I know)
Vergais
Is £400 the actual budget or as you said 'add more later' could you stretch it?
It would work but and it's a rather big BUT.....
The H77 doesn't allow you to overclock the i5K, you might as well drop the wifi dongle and get the Z77 mobo i spec'd earlier.
Second that HDD is waaaaaaaay toooooooo sloooooow :( 7200rpm is what you want for an OS drive, 5200rpm is for laptops and eco drives
THirdly the PSU isn't modular so you have a mass of unused cables you need to hide. Not ideal in a small case, which is why I used the modular P&C PSU
Lastly you wont be gaming until you drop in a GPU.
I realised, that's why I deleted :rolleyes:
That's not a big problem when using the Prodigy.
Right about the RPM.
5400 is a joke unless it's backup or mass storage.
Also the H77 is useless. Might as well get the non K version of the I5.
Atleast you tired fella, unlike the rest of these slackers ;)
I really do beg to differ. Even when building in midi towers I find modular PSUs to be a godsend for cable management. Any excess cables are simply there to block airflow, better airlfow equals better temps. Some PSUs dont fit in the prodigy, OCuk supply the P&C PSU with their store built prodigy so we know it's good ;)
Right, thanks a lot you lot I'm pleased to announce I've placed my order lol.. such a horrible moment... if this goes boobs up im coming for you hono...
I've gone with what you suggested at first with the amd only change i made was the case ( i went with orange it looks nicer IMO and it was slightly cheaper.)
its just a waiting game now with it been christmas and all :D!
