Caporegime
- 21 Jun 2006
I was on 7.0. So that does not make any sense either.
Either way anybody else can try ntfs
This update has completely broken my setup. It’s attached to HT XF9000 soundbar, the matching one for the TV and now when I turn it on, I either get no sound through Sky Q, or not picture. Got to turn the sound bar off and on again, then there is a big delay before both the sound and/or picture return.
Using HDMI 2 for Sky Q with HDMI3/ARC used to the sound bar.
Anyone else noticed that Freeview Teletext looks "washed out" after the update ?
They still do teletext?!? I'm going to have to try this for a lol.
I manually flashed the original Oreo and that was fine for me, except for DTS passthrough.
After the latest Oreo my first impressions were.... Why is the main menu so dim.? How could that have passed QC, kinda obvious.!?
Well at least DTS passthrough now works in Kodi.
I first tried to play the sample off of a fast USB 3.0 HDD in order to verify that the MT5890 is capable of decoding HEVC Main 10 High@Level 5.1 at such a high bitrate. I also stress-tested my network infrastructure (server ⇒ Gibt Ethernet Switch ⇒ Wi-Fi access point ⇒ Wi-Fi client station) to rule out any potential bottleneck. All tests went well with the network achieving a stable 300-400mbps (TCP traffic) over 802.11ac at the same distance as the Sony TV in direct line of sight of the access point.
..... While WiFi Speed Test, downloading data via TCP from the server to the Sony TV, attested a 100mbps on average with previous firmware versions, Nougat at least raised the bar to a stable 200mbps.
Mine hasn’t updated yet but for some reason Netflix and only Netflix has gone all “soap opera” effect on me and no matter which option I choose I can’t get it back to normal. What is also weird is that watching Prime the image is super grainy (noisy) particularly footage of the sky
Anyone else have this issue or know how to rectify it?https://www.sony.co.uk/electronics/..._x90xxf-series/kd-49xf9005/downloads/00016211About this download
Benefits and improvements from the latest update
- Improves Wi-Fi connectivity with certain routers
- Improves readability of the on-screen menus on specific models
