Yep - same here, installing nowJust had a Update pushed out to mine. 58.0.A.3.31
edit - apparently this enables wifi calling if you are on a O2 SIM according to the reddit thread
Can't install....need WiFi for a 75mb update LOL
Update done, said WiFi calling installed, but how do you enable as I tried a call with only WiFi on and it didn't work?
Only works if you have an O2 SimI can't find any WiFi call settings in there. Guess that update didn't quite work
yeah, O2 sim in phone, MyO2 says I have it setup, but I cannot see anything on the phone itself
I may may need to ask in an Xperia forum.
Still no notification when phone is plugged in on how long it will take to charge or anything on lock screen that it is charging. Just the small battery top right with the lightening icon to show charge.
Outlook, used to emails, vibrates every time an email comes in even though it's set not to. This also vibrate also happens when in DND.
If you go settings then search lock screen preferences. At the bottom under show all notifications, is that set to show all ?
No results....What happens if you go into settings then just search wifi calling at the top. Does anything come up, as you need to switch it on in there first.
Mine shows the time when charging.
https://imgur.com/Jljd1yX
One thing i cant seem to get to work is the phone to link via Bluetooth to a Chromebook.
What's your settings?
Also screen protectors. What's everyone using? The one from amazon I bought sucks, doesn't fit correctly and every review left on it says the same. Sadly all amazon products appear to be saying the same thing.
Link below. Fits perfect, put phone in case first then slot screen protector after.
https://www.mobilefun.co.uk/olixar-sentinel-sony-xperia-1-ii-case-glass-screen-protector-black-80868
