- 8 Nov 2006
Excellent, thank you for your help! i'll look into that.
I have no idea what camera's they are but I need the video recorder box to plug them into
So it needs replacing. The hard drive works though! Which is a bonus too.
Cheap as possible, It just needs to record with some basic playback functions!
Well, more information is needed. Are they IP or Analog? A picture of the connector will answer that.
The picture is reasonably clear although it could be better.There are no obvious stickers, markings or anything on the cameras or recorder boxThe picture is reasonably clear although it could be better.
Anyway, Pics. Not the best but that's all there is to show!
http://imgur.com/SjKYr50
http://imgur.com/JAZC5G2
http://imgur.com/jRPUkSE
http://imgur.com/cO78Mv5
Hi all,
Found this thread after doing some research (should have search first I guess) but it looks like want I was planning looks good but wouldn't mind an opinion please?
This is for at work in our warehouse just FYI. So I have seen this kit:
http://www.cctvkits.co.uk/hikvision-3mp-1536p-2-4-cam-kit-builder.html
With 4x EXIR bullet cameras (dome's will get very dirty I imagine and it's a bit damp too and have seen problems with misting?). Also upgrading to an 8 channel DVR for more cameras in the future and was going to get 3TB. Would this be enough? Was going to go for 6mm lens.
Questions also on the software. Does this kit come with software or would I need synology which you keep mentioning? Need to be able to view it remotely as the DVR will be set up in the warehouse with no screen so want to view it up in the office (different network) and also via iphone / android.
Cheers
I also have read this thread all through over the last week and I have one question - I am going to a CCTV shop not more that 40 miles from me to buy a Hikvision 7608 as I feel the price is right and I can take it back if needed -
I have decided to put NVR on desk with PC but I have no room for a monitor for it - My PC has two monitors - one connected with HDMI and other by DVI -
Now can I plug NVR by either HDMI or VGA to this second monitor and if so how can I switch from PC to NVR-- I prefer both monitors on while on PC - makes things easier .
By reading this thread and looking at youtube I have a decent idea of what I need to do - my only problem is I have a bungalow and need a camera for front door and back door - That will put them within easy reach of anyone. - There is no way I can get them higher unless on a pole - forget that. - the two gable ends will be fine for other two cameras.
Thanks
The 8 channel NVR is a good idea as it seems to allow up to 50Mb/s recording over the 8 cameras it supports. I use close to 40Mb/s when using 6 cameras, and that is with compromise as my NVR has a max of 40Mb/s.
Check that it allows POE across all 8 ports, mine only powers 4. Also each camera will use 6w of power at night, when IR is on, so for 8 cameras you will need close to 50w. Obviously that would not power a PTZ type camera.
I prefer the turret type camera over bullets or domes. There is a turret listed in the picture of the link you included. They give the impression of being less prone to vandalisation and I have found the packaged brackets of a bullet to be a little flimsy. I would not get domes, as you have noted, nor a camera with a ring of LED's.
As for a 6mm lens I would download the Hikvision Tools (linked in this thread or search) as they include lots of useful utilities. One of them being a lens selector to help you choose the lens suitable for your needs. 6mm more zoomed and less FOV than a 2.8 or 4.
Consider also additional lighting and additional IR lighting, no matter how good the EXIR cameras are additional lighting is most useful.
I record 6 cameras and have two WD Purple drives, one rests whilst the other records and then they are switched as one fills, there is a total of over 6TB and that lasts for around 21 days or so. Variables will influence that but download those tools, linked in this thread or search, and there are bitrate calculators etc to help you work that out.
Also there is a lens selector tool which has some use to help you decide on what lens to choose.
Software wise. The 4200 client is useful for Windows and the 4500 Hikvision client is good for Android. There is also the means of accessing the NVR via a browser, as well as each camera. iPhones are for girls so I can't help you there.
The software you download but I temporarily used an old VGA monitor to connect to the NVR to initially set it up, IP, Gateway etc etc etc.
By turret do you mean the domes type 4 on that product? I may get a mixture as it depends where I'm mounting.
I'll do some measurements with regarding the which lens and use the chart as said.
Have you ever used a wifi extender with a camera? We've got another floor and rather running a cable up a stairwell it may be an option.
Cheers
I have five of those and they seem quite rugged and have been outside for some time now with zero issues. Compared to the bullet they do seem to be less vulnerable to being wrenched or pulled away etc - although you can set alerts of that. Still if in reach the bullets can be tilted etc and that will not trigger an alert.
Hi all,
Cheers
Yer just been looking at the locations in the warehouse and probably will go for a coupe of 4mm lens and a couple of 2.8mm.
Cheers
