Street Fighter 6 coming with "immersive" single player mode (2023)
What pad or stick will you guys be using on PC?
I was looking to get a Hit Box, but my God, I've just looked up the price and it's close to £300. That is absolutely insane. I still have an OG SFIV Tournament Edition stick, so that will get me by for now.
My stick cost I think around £150, so I have no idea how another 4 buttons to replace the joystick can add anything other than the cost of those buttons. What's that, like £5 each for 4 Sanwa buttons?
£2.70 a button at Arcade World UK
They have the QANBA B1 Titan Arcade Fighting Stick - PS5/PS4/PC which is great for £210
I've never ordered from Green Man Gaming, but went for them as the Steam Ultimate edition price is a bit extortionate (£75 vs £90). I'm hoping I still get the pre order bonuses though; still not received a key yet.
It states you get the preorder bonuses from GMG on their site. I've not bought yet but it's one of the reasons I'll be preordering with GMG even though cdkeys.com is cheaper. Need my preorder Chun colour!
I'll be using my custom stick with Seimitsu LS-56, Seimitsu buttons and Brooks UFB
Might buy this, it would be the first streetfighter game ive bought since the early 2000s if i do lol looks very good though, im not as good at fighters as i used to be when younger though :(
Which one did you play in the early 2000s?
Actually, the game was from the 90s but bought it again in the 2000s and carried on playing it then lol streetfighter 2 turbo and street fighter 3 are the last 2 streetfighters ive played haha
EDIT: unless you count the marvel vs capcom games, owned one of them as well on dreamcast :)
SF6 will be a doddle to get into, they've made it easy to play but hard-ish to master. I'ts like a little less technical that SF4 I'd say
Do you have any experience/thoughts of the LS-56 vs Seimitsu's other offerings? After I posted about my TE stick earlier, I started looking at some upgrades, as I've left it stock from whenever it was released (what was it, 2009? 2010?), so I was looking at LS-40 vs 32 and 56 after I posted that.
I have all those sticks and decided on the 56 with Kowals short through mod. I used to use the 32 before making the change but I like the shorter throw and engagement of the 56. The 40 also has shorter throw but you can't buy an octagonal gate for it. So I 3d printed one which works nicely. But not sure if it was just my 40 but I always left like the ball top was slightly loose which I think is actually a bit of movement with the shaft cover. Either way once felt it couldn't be unfelt.
32 has longest throw and engagement of the 3
40 is shortest throw at stock and similar spring weight as the 32. Uses the same spring but slightly longer shaft.
56 is shortest engagement but thrown between the 40 and 32 when at stock. Also has the tightest feeling spring of the 3.
I have been thinking of going back to the 32 though....I have too many choices.
I have a JLF also but prefer all my Seimitsu sticks to it.
I have a SF4 TE stick (Xbox)I bought back in the days. Only used it maybe 2 days but couldn't commit to it and went back to pad. Need to sell that off at some point.
My key just came through. Managed to activate it on the mobile app as I'm at work at the moment - can't quite check if it's all normal with the bonuses exactly like I had preordered directly through Steam, but it's showing in my library and all, so I assume it'll be fine.
If its showing in library it will be there.
@TNA Any sign of your cdkeys order?
