- 17 Dec 2008
Hello, with the iPhone 13 Pro, when pressing the power button once it turns on? I thought the power button needs to be pressed and held?
I don’t recall that ever being how it works.I thought the power button needs to be pressed and held?
So the button doesn’t need to be held to power on the device?I don’t recall that ever being how it works.
Thanks.No, I’m fairly sure it’s always been just a single push to power the phone on. I don’t turn it off fully very often but have just done it a couple of times to check and I’m pretty sure that’s the behaviour I remember on all iPhones.
13 ProMax still the undisputed battery king
Upgraded from a iPhone 8 Plus to a 13 Pro (also 256gb) two months ago, after having the 8 plus a few years - roughly since the iPhone X came out.
How have you found the change in terms of comfort in the hand (as in sharp edges v rounded)?
The main highlights / differences to me are the Screen (the resolution + 120hz refresh rate), cameras, FaceID, speaker is far better. It is a heavier and bulkier phone though than the 8 plus - immediately noticeable when you hold both in hand side by side. Generally speaking the rest of the experience feels the same, as expected but the battery life is amazing, could nearly go two days without needing to charge. I was put off going for the ProMax as it just felt unnecessarily large in the hand, definitely don't regret just going for the Pro.
I find it hard to justify the cost of the upgrade considering I felt the 8 Plus still did everything I need a phone to do and was still quick enough when it came to day to day use, apps etc.
How have you found the change re how comfortable it feels in the hand (as in change from round edges go sharper edges)?
Well i changed from a Samsung s21 ultra to the iphone 13 pro max 1tb ...
A few things i do not like so far.
Notifications:- you cannot swipe right to dismiss them individually(unless I'm missing something} All or nothing.
Navigation:- around the phone itself. using gestures. i am used to using Swipe left to go back ect.
Email i am currently having major issues with my Gmail accounts. Unless i actually go into the mail app i get no notifications everything is set to push ect. driving me nuts.
is there a better email app to use with ios ?
If i can sort the Gmail problem i will be happy.
If you expand a stack of notifications you can swipe individual ones and select clear.
Tried the Gmail app ?
This may or may not be helpful but I have a couple of gmail accounts configured in the default mail app on my phone and notifications do work perfectly for them. I don't have to manually go into the folder or anything like that, it appears to work as well as iCloud email for me.Thank you for the reply. i was kinda hoping the default app would work. it does work if i manually go into the mail folder it then syncs and the emails come. but unless i go into the mail app i have no idea i have emails.
Swipe right to go back and swipe left to go forward.Well i changed from a Samsung s21 ultra to the iphone 13 pro max 1tb ...
Gmail doesn’t push to the iOS Mail app. The best you can do is set it so it ‘fetches’ email every 15mins (that’s the smallest time).I am wondering if it to do with the notifications rather than the Gmail accounts themselves.
