If it's not being reported in the media, how did you find out that most of the resident are illegal asylum seekers? Also, what does "illegal asylum seekers" even mean?
I suspect the source is either a bloke down the pub or some form of hate site.
So the three impacted Plymouth towers are quite local to me (same council ward, the towers themselves are about a mile from my house), and comparing the two cases makes for interesting reading.
The cladding of the three blocks in Plymouth was completed in 2000, commissioned by the local labour government and under new labour, during a time of large public spending increases. That, for me, kind of puts pay to the idea that austerity or any particular political party is at fault.
The insulation used behind the cladding is different, using Rockwood rather than polyisocyanurate as the material, which interestingly ties in with the statement from the metropolitan police that both the insulation and cladding at Grenfell were part of the problem. (There have been fires in the towers in Devonport that have been contained to the flat as expected).
This further reinforces the idea that something went very wrong at Grenfell, as the cladding seems to have been ok when installed correctly elsewhere. While I support in full the current approach of resolving any buildings with incorrect cladding on them, we need to ensure that the focus on the cladding itself doesn't mean we overlook other aspects.
http://www.plymouthherald.co.uk/dev...adding-fears/story-30407499-detail/story.html
Are you saying (in summary) that because different, essentially safer cladding was used in the plymouth blocks 17 years ago you believe that austerity and current government effectively are proven to have had no part in the issues at Grenfell as I can't see how that follows.
Rockwool is generally the cheaper option compared something like celotex as used in the Grenfell tower, so I doubt that choice was due to austerity.
But no, my key point was that we should not get distracted looking at cladding to the isolation or other factors, nor blaming current administrations for problems that span across multiple areas with different histories or when the cladding was fitted in different economic times.
What matters is working out what went wrong at Grenfell and ensuring it cannot happen anywhere else.
It doesn't feel that way when watching the news. Trying to blame others and save their own behinds at the same time trying to pretend they care.
Nonsense!
Fire resistant and non-combustible Rockwool is more expensive then the cheap polyethylene core cladding used at Grenfell
Why are you talking about polyisocyanurate ??
Grenfell didn't use polyisocyanurate, the cladding was the cheap & nasty polyethylene
The insulation is part of the external cladding! But yes I understand the most combustible part was the cheap & nasty polyethylene, it's maximum continuous operating temperature is nearly half that of Polyisocyanurate (80C compared to 140C)
With regards to Rockwool then I agree, adding any type of mineral based product will improve the overall fire resistance.
Your mistaken, the insulation celotex RS5000 iirc was mechanically fixed to the frame, then there is a breather membrane then a there is a 35-50mm airgap then the cladding panel on an aluminium frame (fixed to the concrete frame).
Two products, celotex and raynobond. The insulation was not part of the cladding.
