I would try to talk with OCuk again and tell em that it came faulty.
I agree with you in principle but it will be very difficult for Minato to get a successful rma - but certainly worth a shot.
The major problem being; he's already admitted, within his first rma, that he fitted the CPU and OCuk will justifiably insist that the fault may have occurred due to 'dodgy fitting'. This type of fault is notoriously difficult to get resolved even when retuning a MB untouched, other than the protective cover. So Minato's admittance to installing the CPU may well have scuppered any chance he had... :/
I, like you, suspect it may have been a manufacturing fault - it could have been a badly formed pin that broke as a result of 'proper' fitting of the cpu – it’s just really hard to prove.
If you were going to try a rma Minato – the 'badly formed pin' point may be a good reference point – but it will be an up hill struggle just because of the type of fault, unfortunately.
Worth a web note just to see how the ground lays...
Additional: We're treading on dodgy ground here - so be careful with your reply Minato
