Wet pc's and insurance companies..
I just had a similar situation with Abbey and "the source" and I refused to let them touch the machine as I felt the offer was derisory and the person i spoke to at there end did not have a clue even though he was "an I.T technician" they wanted me to send my machine to them with the watercooling system fully filled so they could see where it had leaked.
after 6 weeks of messing about going back and forth and having cunninham lindsey (investigation company) out to interview me they have settled on sending me a cheque for £2200 based on a spec from OCUK.
luckily it was only my media PC rather than my main machine but the wait has been killing me.
Just keep at them and they will see things your way m8
Thanks for the words of wisdom so far. I have emailed the full spec to the source and they should be getting back to me today.
How did you get OCUK to spec you a similar pc? Can someone put this in motion or let me have an email address to send to.
A couple of options would be nice via email then i can send them off and see what happens, and of course i will be spending the money with the right company...
Cash would have been nice as i was thinking of a conroe system, but i guess the 3.0 prescott is still current?, how about the AGP x850 though, isnt that now dead and they should be supplying a current pci-e gfx card and board?
Ive emailed the company back and put a link to this thread in it...
Im not greedy, just want what im paying for.. Dont think i will continue the £1500 pc cover though anymore...
I think you spec it yourself or get one of us to spec it for you and then send it off to them. Or maybe the prebuilt range?
Presuming it's 'new for old', I don't see why you can't have Conroe rig. Same goes for PCI-E graphics card.
Thanks, have emailed ocuk and the source. Trouble is no-one wants to tell me what the pc has been valued at so speccing is hard to do...
I just filled a shopping basket to replace the items and mailed it off to the insurers and they checked the items against the reciepts I still had and wrote the cheque.
doing that now..
i kinda just chucked this together as a rough equal, thoughts people?
I know some of the bits mite not be to alls tast but its easy to make the insurance understand if the makes are the same.. guessed on the ram front though as i aint a clue anymore..
REFERENCE DESCRIPTION QUANTITY PRICE COST REMOVE
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£194.99 £194.99
CA-090-CM CoolerMaster Stacker 830 - Silver Trim (No PSU) (CA-090-CM)
£129.95 £129.95
CA-005-TG Tagan TG530-U22 530W ATX2.01 2Force SLi Compliant Silent PSU (CA-005-TG)
£59.95 £59.95
MY-063-OC OCZ 1GB (2 x 512MB) PC5400 Dual Channel Gold GX XTC Series EL-DDR2 (OCZ26671024ELGEGXT-K) (MY-063-OC)
£69.99 £69.99
HD-095-WD Western Digital Raptor 36GB WD360ADFD 10,000RPM SATA 16MB Cache - OEM (HD-095-WD)
£66.95 £66.95
HD-000-WD Western Digital Caviar Special Edition 80GB 800JB ATA-100 8MB Cache - OEM (HD-000-WD)
£27.95 £27.95
SC-037-CL Creative Sound Blaster Audigy 4 7.1 EAX Sound Card - OEM (SC-037-CL)
£30.50 £30.50
MB-107-AB Abit AW9D Intel 975X (Socket 775) PCI-Express DDR2 Motherboard (MB-107-AB)
£119.99 £119.99
GX-044-CO Connect3D ATI Radeon X1800 XT 256MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-044-CO)
£114.99 £114.99
CD-054-SO Sony AW-G170AB2 18x DVD±RW x12 Ram Dual Layer DVD-Writer - (Black) OEM (CD-054-SO)
£18.95 £18.95
Subtotal £834.21
VAT £145.99
Total £980.20
:confused:
Another Quote...
And so the story continues... :rolleyes:
The new qoute....
Chassis type CoolerMaster Praetorian 732 Aluminum Case - Silver (CA-088-CM)
Power supply 400W Power Supply
Motherboard ECS P4M800 Pro SKT 775 M-ATX S/V/L AGP
Processor type Intel Pentium 4 531 3.0GHZ 775
Memory 1GB OCD Gold Plated 5400
Hard drive details 160GB SATA 7200RPM 8Mb
Modem Zoom Hayes V92 V/F/D Internal Modem
Optical drive Sony Internal DVD-RW+/- Dual Layer
Optical drive None
Network card Integrated 10/100 LAN
Sound Creative Audigy SE 7.1 OEM
Speakers N/A
Graphics adapter Nvidia Geforce 5500 256MB AGP
Operating system Microsoft Windows XP Professional
Monitor None
Software Power DVD/Nero
Other features None
FDD Sony 1.44mb BlackFloppy Drive
Keyboard Logitech Internet Pro Keyboard
Mouse Logitech Optical Mouse
HELP"!!!!!!!!!!!!!!
The new qoute....
Optical drive None
Speakers N/A
Monitor None
Other features None
HELP"!!!!!!!!!!!!!!
tell them you want a like for like replacment of parts.
Video card is still awful.
As VeNT says - push for like-for-like. If they can't manage that, then they should at least try and get close...and that spec just isn't.
Seems like they have a load of cheap pre-built PC's that they need to get rid of. All your original components are well known brands so you want the same...It's like them replacing a BMW with a Lada.
Send them a link to something pre-built from the OCUK shop seeing that they are insisting on pre-built.
Dan
I'm having same issue with my insurance co, because my PC is a bit older (athlon 3000 etc) they wanted to replace it with a £300 dell, but without my OCz ram, Abit mobo, Geforce 6600GT graphics card etc
You might be in luck my friend, I actually work for the source claim support and am actually at work there now.
any questions i can answer?
Also you are correct, you are not being offered like for like, this may be for more than one reason but should be sorted as that is not a fair replacment.
Hope you can help me then mate!!
Not being funny or anything i just want the spec the same as the one i had before, or a cheque or whatever..
Nothing to do with the source but i will be changing my house insurance after this as i pay extra for the pc as an individual item upto the value of £1500
O.k. I have found your claim and your original system, you are being dealt with in the walsall branch and they are currently getting a tech to look into it.
You should get a call back from them today.
VeNT said:
Team OCUK to the rescue!
Thanks Colbaker will wait and see...
Although a techi has been looking at it for 2 weeks and i keep getting promised calls...
But we are all busy is guess, especialy in big business..
Dont suppose you can make it into a conroe of some sort when its comes back!! :p
im still unsure how you work out like for like on these pc's.. mines 12 months old now at least..
This would be about right performance wise imo, I'd be happy with it, but it really depends if they are going by the value of that tech now or when it was purchased. If it is just to provide equal performance then the E6600/X1800 XT system you specced is WAY OTT.
Akasa Eclipse 62 Aluminium Case - No PSU (CA-005-AK)
£69.95
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail
£74.99
£30.50
Seagate Barracuda 7200.10 320GB ST3320620AS SATA-II 16MB Cache - OEM
£62.95
Tagan TG480-U01 480W ATX2.0 SLi Compliant Silent PSU (CA-000-TG)
£51.99
GeIL 1GB (2x512MB) PC6400 800MHz Ultra Low Latency DDR2 Dual Channel Kit
£99.99
£18.95
Asus M2N-E (Socket AM2) PCI-Express DDR2 Motherboard (MB-147-AS)
£57.99
AMD Athlon 64 3500+ 2.2GHz (Socket AM2) - Retail (CP-164-AM)
£54.99
Subtotal £522.30
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £10.95
VAT £93.32
Total £626.50
If you don't get a call today then you should get one tomorrow, I have sent the relevant people an email explaining what the problems are with the claim.
Im at home now and didnt have a reply when i left at 5:30.
