This. I feel uncomfortable if the ash tray is open (needed for the lighter socket),
Here is your solution.
I have one plugged in to my 12v socket and it sits pretty much flush, so my ashtray closes and boom, permanent USB sockets.
Thing is the E46 and other BMWs still power the lighter socket when the car is off so there'd be some minor drain on the battery constantly with that in
How long have you had it? Every USB charger I've ever had has shorted out after a few months :/
No car charger I've ever had has even been able to keep the battery level never mind charge it whilst in use. After the last one broke I haven't even bothered getting a new one.
How efficient are these cheap USB things though, or more importantly, any chance of one failing while the car is locked up one and catching fire? Tiny tiny risk I admit but can never be too sure?!
Installed upgrade bulbs today:
http://robbiekhan.co.uk/root/temp/Xenons.jpg[img]
Tell you what, if you thought normal E46 Xenons were a pain to install then the M3 is pain++.[/QUOTE]
Have had one in (decent brand) for over a year now with no issues :) Also if you think they're a pig, try doing the passenger side dipped beam on a mk3 MX-5! Fuse box is in the way so the only solution is to jack the car up, take off the front nearside wheel, detach the arch liner, then do everything by touch. Several hours to replace, most of which was spent swearing.
Edit:
[IMG]http://i.imgur.com/xvAF9yB.jpg
Quit doing things properly snips, you're showing me up!
