What does that even mean? I mean like really, what are you saying?I'd also be concerned by the tesla M3LR insurance quotes -national dealershipisn't for free
Were people getting free insurance before Tesla showed up?
![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
You get used to it very quickly and it benefits from being automotive infotainment that actually works, is easy to use and because it’s not running on a a low end SOC from 2006, it’s very responsive unlike the laggy mess on most other marques.
Yeah must be a benefit of not having Apple CarPlay or 3D surround cameras… likely to be headroom when you gear the hardware up for self driving when the sensor set isn’t close to ready![]()
would you want to run a 2nd hand car, privately, without any sensible national dealership - spare parts that take ages to arrive,Were people getting free insurance before Tesla showed up?
Eh?would you want to run a 2nd hand car, privately, without any sensible national dealership - spare parts that take ages to arrive,
and whatdo points meanare the implications on insurance premiums (don't forget what tesla had to do in the usa )
.. also one of the reasons polestar is tanking , just joining the dots.
trading off reduced home charging costs with a £700 yearly insurance premium , maybe, if I was an additional rate tax payer.
jpaul’s posts are actually a direct brain interface - as the thoughts occur in his, they just appear in his posts in the same order, with the same bits missing, without being fleshed into coherent sentences.
This....but with a bit of home assistant automation to turn on the MG when it detects the Tesla being turned onSwitch over to Octopus Intelligent, let them handle the Tesla and use schedules on the MG.
It’s also cheaper and you get more cheap slots.
Yes.Does Intelligent still guarantee the 6 (4 with Go) reduced rate overnight outside of EV charging?
Yes. 23:30-05:30 is always at the cheap rate regardless of other charge slots.i.e if say the Tesla starts charging at say 8pm for an hour or so because prices are cheaper (thus you get the cheap rate) will the overnight period also be retained for everything else (plus the balance of charge on the Tesla up to the charge limit / end of "cheap" window)?
It is something I have been looking at but not made the switch yet. We have shifted a lot of our use into the Go window so would want to retain this - I understand Intelligent will charge the car when the price is the cheapest but I am not sure how this interacts with the specific 6 hour window you would otherwise schedule in.
This is the bit I have always got confused over but its likely me just not interpreting the detail correctly.
Basically, how do I ensure the cars are only charged with the cheap rate elec (charging schedule set on the MG so that ones sorted) and maintain the cheap rate for everything else - easy on Go as its a fixed window so just manually schedule everything.
Maybe I am overthinking everything... Its payroll so my mind is like mush at the mo..![]()
Yes, On Intelligent you always get 23:30 to 05:30 at 7.5p kWh
Anything other times/hours which are added is also at 7.5p kWh - for the whole house use too![]()
You anre over thinking this, there are few downsides to Intelligent.Does Intelligent still guarantee the 6 (4 with Go) reduced rate overnight outside of EV charging?
Yes - thisThe downside are if you have home batteries, because you can get cheap slots outside the usual fixed time. You need to work out a way to stop the car rinsing the batteries outside the usual scheduled slots.
You always get the 6 hour window, plus any others if they decide to charge the car outside this window.
Sometimes people get the odd failure, personally I’ve never had it fail but you can mitigate this if you are using the Tesla integration which you will be. Basically just set a schedule in the car to start charging at 11.30 and the car will always start. IO will override the schedule as needed, if it fails, it will just charge at 11.30. You’ll get 6 hours and that’s enough to add 56% charge to a long range Tesla. Unless the car is below 24% when you plug it in, you’ll hit 80% before the 6 hours is up so there is little risk of using peak time power.
