- 9 Jan 2008
- London/Camberley
You might be able to get a 15% off code from Dell Advantage
Had no idea this would work but just got a bunch of codes so thanks!
Typical. I literally just bought an AW3821DW a month ago
I can't downsize now, this 38" is a perfect size. Any ideas if they'll release a 38" version?
When talking about better pixels and it's oled.... there's no contest
So true, it' another thing Totaly
And about my dilemma - vert hight To Small for me bla bla in infinum!
Well thing is; how I slice it I just cant get over the crazy spec of this beauty, and what a Revolution it truly is - on paper atleast!
And the 38 I was babbling about, I see that its Only have 4 cm extra hight and are by then even smaller vs 32 - 16:9 vert space!
So that Dont impress me at all. So I will just STFU and get this 34, atleast must try it out. Im sure I will be happy in the end. And that exra horizontal space will make up for it. Time for me just to press my face closer to the screen right and enjoy it!
Yeah, I'm in the same dilemma here, better pixels vs more of them?
Convince me Nexus, will ya Buddy
Well dumb me that dident try this!
So now I will never touch the Alienware. I will go for the C2. Need that space, there simply is no way around it!
Update: Totaly changed my mind - for what it's worth!
Tried some gaming tonight on my PG279Q - same vert space (fov) as this UW, as we know!
I hated the bloody supersmal fov. No way I can live with that, no matter how good it May be!
So I will Definetly go for the C2 42 incher, and be immersed!
If it helps, I went from the X34 to the AW3821DW.... and I'm gonna be getting the AW3423DW next month month I would prefer it if they were releasing a 38 QD-OLED but honestly; it's not even a question - the QD-OLED is well worth the size sacrifice (and I do like the larger footprint of the 38)
No idea if AMD GPUs can make use of Gsync the same way nVidia cards can use FreeSync, I guess we need an AMD person to confirm it works
I will almost certainly get the Alienware version though just because why not, unless the Samsung model releases around the same time of course. A mate has got me a student discount code for 15% off with Dell so I shall be using that
What happened to it is way to small and not immersive and like playing on a mobile etc etc. Here is one of your posts from a couple of days ago:
You was so sure you posted it in at least 3 places I saw!
If you're using it for gaming, then trust me, as soon as you get into the game you don't notice the missing height, your peripheral vision works better horizontally than vertically.
For work/productivity purposes, it's a little less clear cut, since more vertical height makes it easier to read long documents etc. without having to scroll, or being able to snap windows to all 4 corners of the screen
Annone knows if I can do a UW res on my CX55, and get the same ratio/ size that the 34UW have?
Would be nice, just for fun to try it out. To get a feel of the dimension
You should be able to set a custom res up in Nvidia settings that will give you black bars at the top and bottom.
Thanks and I know that or via CRU, but I dont know What resolution will = the same aspect ratio and Size as the 34
Didn’t really say much in the post other than you changed your mind as you don’t want to miss outWell if you Can Read - my post Explained it all, dident it!
It's just to good to ignore buddy
3840 x 1620 will give you the same look
