- 1 Oct 2020
haha...freudian slip...I clearly have 4090s on my mind.You have a 4090 already? Are you from the future?
my 3090 is pushing the pixels just fine so far
cool thanksAnd enable Gsync in the nvidia control panel as it may be off by default. Also delete the icc colour profiel you /may/ have in display settings as it can mess with colour output in certain apps. It is not needed. SRGB mode in Creator is nigh on perfect for accurate viewing for normal use and media consumption.
I cancelled my order which due in October and bought the LG C2 42” and am loving it. UKHotdeals has a voucher for 10% of the C2 at the moment.Didn't get the parcel told Dell if doesn't arrive by tomorrow 7pm will cancel the order, I'm not being messed around by UPS they are scum have zero trust in them.
Will buy LG 42 inch C2 maybe or wait for something better.
Yeah got amazing deal on a LG 77 inch C1 few weeks ago from Crampton & Moore no problems with super fast delivery.I cancelled my order which due in October and bought the LG C2 42” and am loving it. UKHotdeals has a voucher for 10% of the C2 at the moment.
Encountered my first issue.. monitor flickers but its not your usual superfast flick, this seems to turn off the monitor look for a signal for about 5s before reconnecting to the input. Only my PC was connected to it. Removed any other connections i had. Happens every couple minutes and does it randomly. Not sure why. If i connect my work laptop which is a HP Elitebook 830 G4, it's all fine.
Also have another thread over in the VR section which is a different issue but also relates to this monitor: https://forums.overclockers.co.uk/threads/monitor-turns-off-when-starting-steamvr.18956133/
Any help appreciated
Low fps?Just played a few hours of Resident Evil 7 on this - a terrifying experience with HDR and ray tracing!
work laptop running using HDMI cable.Work laptop works with the same cable?![]()
That's only on RE2 apparently... A shame since I want to play that with RT and HDRLow fps?
Yeah it took about 5 minutes.Anyone done the panel refresh yet? Tempted to just do mine so the pop up stops coming up every time I wake up the screen.... Suppose I have probably used mine close to the hours it requires now tbf.
Does anyone know if the standard warranty covers burn-in? My understanding is that it does so I didn't go for premium warranty (since I've never needed it in the past with Dell monitors).
Also, should you always leave the monitor 'on' (i.e never turn off the power button in the corner) so that it can do its refresh thing? It can't do it if the monitor is off - am I right in thinking this?
Are there different types of refresh? The message said it may take a few minutes and did so for me.Panel refresh does not take 5 minutes![]()
