- 31 Jan 2022
- UK
Hi chaps, I could really use some of your collective wisdom. Sorry for the wall of text I am about to subject you to.
I bought this gem of a monitor on Saturday the 5th Nov and it was delivered last week on Wednesday. Purchase price was £846 using a discount code and I also have a cashback claim in place.
I've had a chance to play around with it over the weekend and I'm in overall awe with the picture quality in comparison to my IPS XB271HU monitor.
I have two issues however with one of them being a deal breaker. The first issue (not a deal breaker) is that I have bubble wrap imprints and marks along the top half of the screen; I haven't properly gone at it with a microfiber cloth but did do gently when it arrived which removed only a minor amount of the markings.
- No pixel or uniformity issues.
- No discernable flickering (some minor VRR/G-SYNC fluctuation during paused menu in Outer Wilds).
- I cannot notice or am not bothered by the text clarity / fringing having come from a similar PPI display.
- Elevated blacks during the day are dissapointing but it still looks miles better than my IPS.
- July 22 manufacturing date, M0B102 FW ver.
The second big issue which is a deal breaker is the fan noise which has started doing my head in. To share some context, my PC is on the floor to the right of me and has a mix of 140mm Noctua and BeQuiet fans. I previously had all Noctua but they generated some odd harmonic resonance at low RPM which drove my crazy. There's also a server to my left with a similar fan setup where I have set up scripts to turn off the screeching hard drives during idle (yup, I'm super anal about noise).
Now, the monitor fan noise. It's okay within the first 15-30m of web browsing but after the initial period and once it warms up it'll start spinning at a rather uncomfortable frequency and can be heard from a normal seating distance of about just over an arms length. If I put my ear near the panel, the sound is obviously much louder and distinct. Honestly it almost sounds like someone is using the vacuum somewhere in the house. Room temp fluctuates between ~19-21 degrees. Someone on Reddit /u/NartDota captured the noise which sounds similar to mine, albeit amplified: https://drive.google.com/file/d/1G16Q0Eb-lrgTs8KPyydAgNqIzWIj3-s3/view
On top of that it also does a whooshing fan noise (which is the panel fan itself as I understand it?) at random intervals but this doesn't bother me as much due to its irregularity and more pleasant acoustic tone. I cannot hear it during gaming when PC fans and audio kick in. I don't usually wear the headphones due to having bookshelf speakers. I also have a minor case of tinnitus which most would think would drown out noise, but nope.
I don't know what to do. As I've said I'm in awe with the screen, paid a fair price but don't think I can live with the noise.
- Other people report no fan noise or can only barely hear it when placing ear next to screen, so did I get unlucky? I think it's either:
- They really have minimal fan noise.
- They have other noise sources drowning out the noise.
- They are not sensitive to the noise.
- They are partially deaf and unaware, perhaps tinnitus is drowning it out.
- Do I gamble a screen replacement in the hopes I get one with no marks and lower noise?
- Should I return it and wait for the AWF version to release in the UK at the cost of gsync which as I understand it doesnt really add that much apart from an extended VRR range?
TL/DR: Bought AW3423DW and its gorgeous but 2 issues, one screen marks and other fan noise. I'm anal about noise and can hear a faint vacuum noise during non-gaming from the screen.
This is an issue where I am afraid it is up to you. I am not sure which of the fans tends to be the noisy one. I have a G-Sync Ultimate module in my monitor and I can never hear it, even after intense high refresh rate gaming, so I remain unconvinced that it's the source of the problem, meaning going for the F version may not help. I have also heard people saying that their AW3423DW makes no discernable noise, but some say it is very audible. I am just wondering whether you run Windows in HDR more and or what refresh rate you use for browsing? The more power the panel gets the hotter it will run.
It may be worth asking Dell. If noise complaints are infrequent then they will advise you to swap it for another. If frequent then they will advise you to refund it.
I have to say that if it was me, I would return the monitor for a refund and await more information about the F variant, but that's just me - I like to get things sorted in one hit.
