There’s a couple of workarounds on that Dell link I posted above for HDR.Then we can all enjoy it and bask in HDR goodness!![]()
On another note my 6th of March delivery is turning out to be tomorrow!
That's real good mate. I'm really pleasedAnnnnd.... It's here.
Still setting stuff up for it, but just did a quick check, no stuck pixels, no bright pixels, cursory quick glance looks uniform.... But still old firmware for now, so just need to wait for that new firmware to see this in HDR proper.
And of course, many of you were right, this fan is barely audible whilst you're in front of it (it's blocked by the panel itself). Need to get your ear up to the vent to hear it.
Oh, in case anyone was going by auto-pilot whilst setting this monitor up, the supplied Displayport cable does NOT have a release mechanism on it. But it also does NOT have the hooks you usually see on Displayport cables, so removal is akin to HDMI cable removal. Do not get alarmed like I did when I thought I had a monitor and computer stuck together forever...
But back to the firmware, given everything is going so well for me, I'm hoping fortune continues to smile on me, and Dell gets that (functional) firmware out soon. Then we can all enjoy it and bask in HDR goodness!![]()
Nope, screen was brand spanking new levels of spotless, not even any touch marks on the casing until I touched it. Screen was also protected by a flat soft foam screen with bubble wrap on the outside to tape it to the bezel to keep it protected.That's real good mate. I'm really pleased
but..no screen marks from how it was packaged up to you? All good in every way yeah? I still haven't ordered one yet.![]()
It works for me, I did try the HDR True Black work around first then i reverted and tried out Source Tone Mapping, they both look good but i think Source Tone Mapping pips itThe only thing i am unable to do is select source tone mapping when connected to my pc
You have an Nvidia card feeding the signal correct? You have the option to enable Source Tone Mapping with that. AMD card owners apprently don't need to, as the signal is already embedded automatically as part of the Freesync deal.It works for me, I did try the HDR True Black work around first then i reverted and tried out Source Tone Mapping, they both look good but i think Source Tone Mapping pips it
Having used the screen for a few hours I'm gutted i didn't get one sooner, its damn impressive.
Ah I didn’t know that, might explain why he doesn’t have the option?You have an Nvidia card feeding the signal correct? You have the option to enable Source Tone Mapping with that. AMD card owners apprently don't need to, as the signal is already embedded automatically as part of the Freesync deal.
Yeah I found that out myself after finding the same issue. Looking further around, I found that the AMD Freesync embeds it in already if the GPU is Freesync capable. So the Tone Mapping is only needed for NVidia users.Ah I didn’t know that, might explain why he doesn’t have the option?
UPS was the courier for delivery and that was fine but DPD were the courier for the return but generally where I am both are pretty goodShame they didn't use DPD for my delivery/return as it would have been sorted much quicker than UPS![]()
Just received my AW3423DW. Noticed some vertical banding on grey backgrounds and apps like discord. Is this normal? Its bugging me a bit. Otherwise no dead pixels, no fan noise.
Mine had that when I first got it. I ran a panel refresh which took about 45 minutes and I have not had it since.Just received my AW3423DW. Noticed some vertical banding on grey backgrounds and apps like discord. Is this normal? Its bugging me a bit. Otherwise no dead pixels, no fan noise.
I did read from someone else that;that sorted it out.Mine had that when I first got it. I ran a panel refresh which took about 45 minutes and I have not had it since.
Might be worth a shot.
Yeah I saw the Samsung version, there are at least a couple of bugs which were offputting to me, is the ui very laggy??Got the Samsung version, great monitor. Really like the stand as well, no reason to wall mount which is nice.
Good to have smart tv features built in and a remote, all high end monitors should have these features.
