- 23 Feb 2023
- Canada
Ugh! Just noticed a dead pixel near the center of the screen... Should I exchange?Both of mine have it, it's common with OLED
Any issues running the panel refresh this early? Any risk of the panel refresh ruining anything else? I just noticed I have a dead pixel in the middle of the screen, should I exchange? I wonder if a panel refresh will get rid of that dead pixel too.Mine had that when I first got it. I ran a panel refresh which took about 45 minutes and I have not had it since.
Might be worth a shot.
if it's annoying - then yesUgh! Just noticed a dead pixel near the center of the screen... Should I exchange?
Oh cool, thank you. So it looks like it will be possible then.I just tried turning on 165hz 10bit here on the F, and have no problems. But I'm using an AMD RX580. I think I remember reading that the NVidia needed to do something like Custom Resolution or something like that. You'll need to dig deeper on that to know exactly whats needed to be done to get 165hz 10bit, as I don't have an NVidia card so can't test myself for you.
Not that I have encountered.Any issues running the panel refresh this early? Any risk of the panel refresh ruining anything else? I just noticed I have a dead pixel in the middle of the screen, should I exchange? I wonder if a panel refresh will get rid of that dead pixel too.
Interesting issue cropped up for these monitors and AMD Freesync users.
If you use Freesync and connect via Displayport, and go above 120hz, so say 144hz or 165hz, apparently there's an issue with the implentation by the monitor manufacturers, and your system will be much more prone to random crashing. Apparently this impacts AMD users only using Displayport (not HDMI apparently from my quick cursory search, and Nvidia patched this issue out already), and only when using the F style variants that employ Freesync. So that should be all the current QD OLED monitors in this thread bar the original DW, which uses Nvidia's Gsync instead.
Current workarounds include setting up a custom resolution and using that, even if it is 144hz, or 165hz to obtain those refresh rates. Or using a lower refresh rate if you're not in need of the higher refresh rates. Or to turn off Freesync entirely. This impacts all AMD GPU's apparently, and awaiting drivers on a fix. I am unsure if the latest ones by AMD have fixed this, as unfortunately I need to (currently, as I'm still on the RX580) use the May 2022 drivers as they're the only ones that work with some of the stuff I do at the moment.
Interesting as I've used nothing but AMD cards with various monitors for years and they've always been OK, that's why I've stuck with them. There can be a number of reasons why you experienced issues and none of them down to the manufacture's card..
Eh, I assume you meant me?Let's agree to disagree, just as many issues with NV cards and just as many AMD owners without issues. Just because of one post that makes allegations without any evidence doesn't mean this should turn into a AMD bashing contest..
And back on topic..
The card mentioned in those linked threads are the 7900 yes. But if you follow back through a lot of threads that get linked, it's not just the 7900 owners only that was experiencing issues when Displayport +/ Adaptive Sync/Freesync Premium, etc, only that was the biggest one I believe. I myself am still on the RX580 and ran into this out of the blue. Others have reported on other AMD cards too but there was no specific details until I ran into one thread that began describing in detail the technical reasons (Beyond my comprehension level anyway). But thought it was best to keep fellow QDOLED monitor users up to date in case they run into this issue so they don't start trying to diagnose and end up with RMA'ing a good monitor or anything like that that didn't need to be. THAT would be bad.Thanks for the detailed update. I can see only the 7900 card and the 23.2.1 drivers are are mentioned and causing these lockups, am I correct? I'm using those drivers and not suffering from any but have a 6800...
EDIT: seems that AMD has already released 23.2.2 on the 22nd February..
