Caporegime
- 18 Oct 2002
39" one due next year iirc. LG though and prob a heavy 800R curve.I am putting my foot down, I will wait for the 40" 5120x2160 240Hz panels
Too scared of uncool screenshots at 16:9 instead of 21:9
No I ill point and laugh at my own screenshots if they were 16:9
Question regarding the DWF: can it do HDR and 10-bit at 165Hz with DP1.4?
The MSI MEG 342C can do it via HDMI 2.1, I run 175Hz/10bit.Question regarding the DWF: can it do HDR and 10-bit at 165Hz with DP1.4?
Not 100% sure on the DWF model but I believe it will be 8 bit + frc to hit the higher refresh rate.
As confirmed by badass, pcmonitors, Vincent at HDTV test and various other sources, there is basically no difference between 8 bit frc and native 10 bit, there is also some testing by rtings to show that 8 bit frc actually has less banding than 10 bit on oled displays (although in real world usage, probably be nothing in it)
Thanks, I just read up on that and it seems 8-bit + FRC is virtually indistinguishable. Is that what the monitor would use?
I hear there's noticeable banding with standard 8-bit.
That is correct, I've been editing between both 8bit and 10bit and there is no noticeable difference in anything at any point. I prefer 10-bit for 1: Peace of mind and 2: I'm at 144Hz anyway as 175Hz on the DW has frequent VRR flicker in the apps I use often whilst 144Hz has no flicker, so may as well use 10 bit in the process.Thanks, I just read up on that and it seems 8-bit + FRC is virtually indistinguishable. Is that what the monitor would use?
However, if you are on an AMD card then there may be a difference. Nvidia's 8-bit + FRC is basically 1:1 t native 10-bitt, and as I don't have an AMD card, didn't look into that any further so might be worth testing this yourself on your XT!
From what I have read and done, removing any ICC profiles (Colours are not accurate in Creator sRGB mode otherwise) attached to the monitor and rebooting is best. Also, use the Windows HDR calibration tool from the MS store to create an HDR profile for the monitor. Not sure on what is best to do with browser windows and the tabs. I only got this monitor last week, the price was too good to say nomy aw3423dwf just arrived today to replace a aw3420dw.
is there an update to set setup/settings/best practice anywhere?
from a list of things it would seem like:
update firmware
autohide taskbar
pixel refresh settings
set settings on monitor (sdr/hdr)
hdr calibration shennigans
does anybody use an .icc profile? i have one for my aw3420dw when i calibrated which obviously no use now. cant remember how it works without one. windows just figures it out on its own?
In regards to minimizing burn in. the biggest concern i have is internet browsing. mainly chrome tab bar/bookmark bar etc. would it be best switching to a dark theme of some kind? not a fan of dark mode stuff and use default chrome theme but just worrying about static tabs/buttons along the top/side for hours on end.
update firmware
autohide taskbar
Very interesting, always suspected this to be the case but it's nice to get confirmation. It's also good to see confirmation that the Gsync module does not get rid of VRR flicker as some thought, the flicker can still happen, its just less frequent than monitors that don't have Gsync
I have been considering selling my aw34 for a 32 inch 4k model, but now I'm not so sure. The aw34 is the only Gsync model on the market so its the only OLED monitor that has decent VRR flicker handling, making it very unique
